Home > General > opened the bonet for the fist time
David
Spain 2007 Range Rover Vogue SE TDV8 Zermatt Silver
opend the bonnet and noticed that at the back of the engine where the battery sits on the left it is uncovered ? Is it missing a cover ? Also same place on the right is un covered !
Post #35835 11th Nov 2010 8:50pm
dan_uk_1984
I presume you opened the bonnet before you bought the car?
Post #35836 11th Nov 2010 9:00pm
GJOB
2005 Range Rover Vogue SE Td6 Java Black
my battery is uncovered too, i though it was supposed to be like that Shocked
Post #35837 11th Nov 2010 9:06pm
Fox
Why would you do a crazy thing like that! Wink Laughing
Post #35838 11th Nov 2010 9:07pm
David
Yeh cause just to see if it had a motor !!!! lol Just didnt notice !!!!
Post #35839 11th Nov 2010 9:08pm
David
Post #35844 11th Nov 2010 9:22pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Re: opened the bonet for the fist time
There is a guide on here somewhere that involves an egg box, some black paint and a prix stick. Much cheaper than the cover from land rover. 2004 black Vogue TD6
Post #35848 11th Nov 2010 9:35pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
My thoughts
a) Its derived from a tractor so you should be able to see the battery even with the bonnet down.
b) The Battery is very expensive = thing of beauty = so why cover it. Landrover kindly afforded us full on visual battery porn by making the bonnet hinge even further to give a better view Very Happy
c) if it was covered then it would only delay the jump starting of jumbo jets (just pretend there are no + and - terminals elsewhere for artistic impression).
Wink 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #35864 11th Nov 2010 11:10pm
GKP
United Kingdom 2003 Range Rover Vogue 4.4 V8 Cairns Blue
So, the thread title. Does this time only happen when your 'bonnet is open'? Shocked Not sure you should be reading this bit.
Post #35866 11th Nov 2010 11:18pm
