![]() | Home > Technical (L322) > Suspension - loud "pfffft". Now no suspension/no f |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Air spring https://www.arnottindustries.com/part_LAND...id627.html
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8392 ![]() ![]() ![]() |
Sorry, I was sure you had a 2003... my bad... same price though for the later ones, you could just change the one bag now if you want to do it on the cheap and keep the old strut, at least the shock absorbers would still be matched... the bags on their own are only $20 less than the whole strut though...
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
Ian...the arnott struts aren't "new" either.....just new bags.
Very difficult to say where your hole is, a bag, a pipe, or the manifolds, it needs finding first... no point just buying bits till you know what you want... Pete
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
Think it best if you stop driving it around too, until you figure out what is wrong and fix it. No good can be done by running about on the bump stops |
well I had to drive it over to my other property where my tools are but I found the culprit.
Well from what I can make out, your air bag has failed, possibly a little bit quicker than I would expect, but I have no idea as the mileage that your car has done and what sort of ambient temperatures it has been exposed to. My late 2003 ffrr's air bags went pop 2 years ago, just after I'd brought it |
ive read somewhere (one of these forums) that someone spoke to an arnott rep and they said " we don't touch the strut other than checking to make sure it works and paint it and put a new bag" i.e. no work done to the strut itself.
Yep, your right Bilstein made the dampers front and rear with Delphi bags, sounds a good price, I'd go with them... |
Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227 ![]() ![]() ![]() |
Hi,
Mmmmmm, I do remember something about that but can't remember what exactly. There are differences in the suspension of the early SCs compared to the NA engines, maybe that has to do with it ?? More weight due to the SC unit ??? Not sure but remember that remark.
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
I remember the supercharged had less travel and a firmer ride , and they went with supercharged spec suspension on the Hse later on .
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
You said the noise seemed to come from under the dash. Have you definitely confirmed it is the airbag and not the airline to the bag? No longer FF owner but still interested. Present car Jaguar XE
Are the Supercharged dampers not active? That would double the price and then some.... might be thinking of a another make, but in the dark corners of my addled mind I vaguely remember that they were active ( computer adjustable |
