Home > Technical (L322) > Suspension - loud "pfffft". Now no suspension/no f
Page 2 of 3 <123>
miggit
Air spring https://www.arnottindustries.com/part_LAND...id627.html
Air Struts Complete and $100 cheaper https://www.arnottindustries.com/part_LAND...id624.html
https://www.arnottindustries.com/part_LAND...id625.html
It's a no brainer replace the lot and save $200 as well Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #372263 14th Feb 2016 1:32am
Sorry, I was sure you had a 2003... my bad... same price though for the later ones, you could just change the one bag now if you want to do it on the cheap and keep the old strut, at least the shock absorbers would still be matched... the bags on their own are only $20 less than the whole strut though...
It's best to do both, and the shocks at the same time but not essential, the Arnott ones have a lifetime warranty....
Unfortunately these aren't cheap cars to keep on the road... the front bags seem to last about 8-10 years on average, the rears last a lot longer, mine is still on original rears and it's 14 yrs old soon.... Pete
Post #372264 14th Feb 2016 1:33am
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
It's a no brainer ..
2 arnott struts , and 2 hours of your time and your back on the road .
You might save a couple of hundred bucks buying just the bags , but will take to twice as long to disassemble and reassemble , and at the end of the day you will have bolted new bags onto an old shock and top-mount .
It's a bit like putting the old engine oil back in to save a few bucks when doing a filter change .....
Post #372268 14th Feb 2016 3:04am
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Ian...the arnott struts aren't "new" either.....just new bags.
anywhere here are all my symptoms...want to see if this helps. If its a bag I want to make sure I'm ordering the right ones since the entire suspension is on bumps stops now.
- go to pull out of side street and hear a loud PFFFFFFT that sounded like it came from under the glove box.
- Range is giving error "raising slowly" but both fronts are now on bump stops.
- look onto screen and it looks like the rears are lower on the screen...but rears are sitting fine when I look outside the car.
- drive the car a bit further and get the "suspension fault 30 MPH max" error and start to hear a loud clicking/clanking from the rear (lasts about 3-5 minutes) as the rears drop down to bump stops
- now all 4 corners are on bump stops - look on the nav screen and see the rear 2 wheels are flashing red (assuming b/c they dropped to bump stops)...but the front 2 wheels are no blinking red...they have the white dashes/lines.
If i start the car after all 4 corners are on bump stops the rear seems to raise fine, I get a "raising slowly" on the dash and I hear what sounds like a bike pump from inside the car (I'm assuming the compressor trying to pump the front up?). Once I start driving I get the "suspension fault 30 MPH max", loud clicking/clanking from the rear and the rear drops to bump stops and the cycle repeats. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #372516 15th Feb 2016 5:58pm
Very difficult to say where your hole is, a bag, a pipe, or the manifolds, it needs finding first... no point just buying bits till you know what you want... Pete
Post #372534 15th Feb 2016 8:37pm
Think it best if you stop driving it around too, until you figure out what is wrong and fix it. No good can be done by running about on the bump stops Thumbs Up .
Post #372541 15th Feb 2016 9:07pm
horse86
well I had to drive it over to my other property where my tools are but I found the culprit.
The "bike pump" sound was the front passenger side trying to inflate. I jacked up the front and gave the passenger side bag a squeeze and it there was no air in it. I'd squeeze and you could hear the air rushing out. Tried the driver side a squeeze and it was solid...couldn't squeeze it. So this would lead me to believe a bad bag. I mean I guess in theory it could be the air not getting to the bag to fill it (issues with the line on that side)...but the bag wouldn't be totally deflated like it is unless the actual bag had a leak I'm thinking.
Unless there are other ideas I'm off to buy 2 front Arnott struts tonight 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #372552 15th Feb 2016 9:57pm
miggit
Well from what I can make out, your air bag has failed, possibly a little bit quicker than I would expect, but I have no idea as the mileage that your car has done and what sort of ambient temperatures it has been exposed to. My late 2003 ffrr's air bags went pop 2 years ago, just after I'd brought it Evil or Very Mad , so I would have said that if it was a 2005/6 then age was the deciding factor. Yours' could be age related or just bad luck and some grit / mud that has worn the rubber.
As for changing 1 or 2, it's really up to you.... you could just change 1, it turns out to be age related and you'll be doing it all again very soon Evil or Very Mad And judging the way that the air bags wear in general, you'll end up changing both in the next 18 months or so.
You said "the arnott struts aren't "new" either.....just new bags. " I would find that very hard to believe, as they are recon, they should be changing the guts of the damper to. So if they do change the damper as well, if you only do 1 then you could get uneven damping across the axle which will effect the handling and stability Shocked Personally I would do both, and then add that to the never to do again list, not because it's difficult Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #372567 15th Feb 2016 11:17pm
horse86
ive read somewhere (one of these forums) that someone spoke to an arnott rep and they said " we don't touch the strut other than checking to make sure it works and paint it and put a new bag" i.e. no work done to the strut itself.
I'm actually considering the bilstein air strut option now as I am able to get a set of fronts States side for around $550 or so and they are completely new/not rebuilt/no core charge etc.. Apparently they were the OEM supplier. But these are bilstein strut with Delphi bag. I will be changing both sides. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #372568 15th Feb 2016 11:25pm
Yep, your right Bilstein made the dampers front and rear with Delphi bags, sounds a good price, I'd go with them... Thumbs Up Pete
Post #372569 15th Feb 2016 11:35pm
Road Stone
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Hi,
I've just been through the exact same scenario, a blown front air bag on the original Delphi strut.
I replaced both fronts, like for like. Easy no real hassle but the main thing you'l notice is the ride quality. A vast improvement over the 9 year old originals that came out:
I'd suggest just change both whole units.
Cheers, Jerry
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  THIS WRECKAGE
Post #399708 9th Aug 2016 5:24am
ebajema
Mmmmmm, I do remember something about that but can't remember what exactly. There are differences in the suspension of the early SCs compared to the NA engines, maybe that has to do with it ?? More weight due to the SC unit ??? Not sure but remember that remark.
I'd go with the Delphi anyway as you also replace the shocks and they need replacing anyway at the age of yours, probably !! MY 2010 5.0 SC Galway green and sand interior!!
Post #399789 9th Aug 2016 3:30pm
Ian c2
I remember the supercharged had less travel and a firmer ride , and they went with supercharged spec suspension on the Hse later on .
But when I asked arnott a couple of years ago they told me the only difference was a weight added to the top of the strut to help with oscillation vibrations .
Post #399792 9th Aug 2016 3:45pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
You said the noise seemed to come from under the dash. Have you definitely confirmed it is the airbag and not the airline to the bag? No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #399818 9th Aug 2016 5:42pm
miggit
Are the Supercharged dampers not active? That would double the price and then some.... might be thinking of a another make, but in the dark corners of my addled mind I vaguely remember that they were active ( computer adjustable Shocked ) Yesterday I couldn't spell Engineer... Today I are one!
Post #399869 9th Aug 2016 10:11pm
Page 2 of 3 <123>
