Home > Technical (L322) > Oil leak cam covers 4.4 v8 |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
I just don't understand a garage doing that, barking in my view for a few pence more.
30th Jan 2016 6:46pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 |
The old ones go very hard, and the bolt bottoms out with little tension given by the already thinned rubber seal. . Yes do one at a time, they are about £1.50 each I think. Observe the torque setting, or just do up gently tight. Don't need to be really tight!, you are screwing steel into aluminium. 10mm socket is all you will need. |
30th Jan 2016 11:12pm |
calletso Member Since: 27 Jan 2016 Location: North Yorkshire Posts: 12 |
Thanks for the reply - £1.65 each from Landrover so went for some febi bilstein branded ones (16 for £12 delivered).
10th Feb 2016 6:38pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8314 |
Chucking oil everywhere is good... it means the oil ways to the top of he engine aren't blocked...
10th Feb 2016 7:16pm |
Actually looking in the engine without the oil cap on - no surprise oil got flung everywhere with the timing chains where they are! Has put my mind at rest! |
11th Feb 2016 8:21pm |
