Home > My Range Rover > My new '12 Autobiography (finally got it!) |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1653 |
Hi and a warm welcome.
29th Jan 2016 5:51pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
PM sent
29th Jan 2016 6:39pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
Hi hello & welcome sir |
29th Jan 2016 6:44pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7923 |
For occasional use - I would recommend Thule roof bars
29th Jan 2016 6:56pm |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
Congratulations and welcome.
29th Jan 2016 7:22pm |
d3rm0 Member Since: 12 Feb 2012 Location: UK Posts: 438 |
Nooooooooooooo
29th Jan 2016 7:39pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Love the seats Good looking RR 2015 4.4 AB
29th Jan 2016 7:43pm |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
nice Range keep the kit on it _____________________________________________________
29th Jan 2016 8:00pm |
exalin Member Since: 14 Jan 2015 Location: Cheshire Posts: 69 |
I have a set of Whispbars that fit into the fixing points on the roof without having to break off the plastic flaps that cover them. They lock to the roof and are really easy to fit/remove plus very quiet at speed too.
29th Jan 2016 8:24pm |
bluehorseshoe Member Since: 29 Jan 2016 Location: Fairfield County, Connecticut Posts: 27 |
Thanks for all the comments.
29th Jan 2016 10:52pm |
Ok because you were concerned about clearance and your rear bumper is lower and it may be a bit longer than stock which makes ground clearance worse. The stock one also angles up a lot more (more ground clearance) 2014 FF Autobiography 5.0 SC
30th Jan 2016 1:00am |
Croz1 Member Since: 27 Dec 2015 Location: Denver Posts: 10 |
Hi Bluehorseshoe - glad you made it over to this forum!
30th Jan 2016 3:10am |
I've got no experience other than Thule.
30th Jan 2016 8:33am |
If you want a roof rack that is actually
30th Jan 2016 9:56am |
