Home > In Car Electronics (L322) > Key fob synching issue
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Hi all, had a low battery issue and my primary remote key fob stopped working ie I could not remotely lock or unlock the car but am able to start the car once I am inside. The spare key works fine on all functions.
Replaced the battery in the key and carried out the synch procedure (ignition on off, press and hold unlock button and press lock button 3 times). This has worked but then the other key stopped working. Have tried a number of times in delude rent sequences but the synching of one key is de-synching the other one.
Any ideas? I have tried starting with one key and then the other and even reversed order in which I insert and synch the keys but no luck. Would want to avoid a trip to the dealers if I can.
Many thanks African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #336741 10th Jul 2015 8:00am
johnboyairey
i had to do exactly this the other day.... you have to do both (or all) keys straight after each other, without 'starting again' ie do one, then immediately do the other, firm presses of the buttons etc. doors should lock/unlock etc. (each time)
then rejoice/smile etc, and spend the money saved (from the dealers non-visit), on a tank full of fuel..
Post #336742 10th Jul 2015 8:05am
DeRanged Rover
I tried that several times without joy. The first key would sync (doors lock/unlock) but then when I did the same for the second key and the doors lock/unlock on that one the first key doesn't work any more. Sad
Is there anything else I need to be doing once the sync is complete and the doors lock/unlock? E.g. insert first key back in and redo?
C African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
Post #336774 10th Jul 2015 1:22pm
johnboyairey
all I think I did after doing both, was to try each one (in my hand) whilst still in the car, lock/unlock it worked 2nd time for me. maybe it didn't work on the time(s) you tried. I thought I had to rush, but it seemed to be easy to do, once you had done a 'rehersal'
Post #336778 10th Jul 2015 1:27pm
DeRanged Rover
Did you put the key back in the ignition after each key had synced? That may be where I have been going wrong. Will try just doing the ignition thing first and then syncing keys one after the other with button press only. African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
Post #336783 10th Jul 2015 1:45pm
johnboyairey
Yes, I just inserted key turned to 1 withdrew clicked each keys buttons, and got a clunk/clunk then did the other, again clunk/clunk, then I just tested them in my hand. (Clunk/clunk.). Then got out and locked it, and it chirped, so to me they were ok, and since then I have used both normally. And I tried doing the button hold and windows down all ok today too.
I'm happy!
Post #336798 10th Jul 2015 6:18pm
DeRanged Rover
All Sorted!
My mistake was re-inserting second key into the ignition thus restrarting the sync process.
Many thanks John! African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
Post #337182 13th Jul 2015 9:59am
Stormin
2003 Range Rover HSE Td6 Epsom Green
Deranged Rover
I'm having the same problem as you had with my keys, I sync one key and the other loses the will to work.
From reading your thread should I put both keys in the ignition after sync or just one Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #369697 31st Jan 2016 10:53am
Put one in, then just push the buttons on the other. If you put the second in then you start the procedure again. There is nothing that can't be fixed with a hammer😜😜
Post #369704 31st Jan 2016 10:58am
Stormin
Northernmonkeyjones
You are a star
Works great now
Thanks Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
Previous cars
1973 Mini 1000
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1996 BMW 730
2003 Honda CRV
Post #369707 31st Jan 2016 11:19am
