Home > In Car Electronics (L322) > Key fob synching issue |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
i had to do exactly this the other day.... you have to do both (or all) keys straight after each other, without 'starting again' ie do one, then immediately do the other, firm presses of the buttons etc. doors should lock/unlock etc. (each time)
10th Jul 2015 8:05am |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 |
I tried that several times without joy. The first key would sync (doors lock/unlock) but then when I did the same for the second key and the doors lock/unlock on that one the first key doesn't work any more.
10th Jul 2015 1:22pm |
all I think I did after doing both, was to try each one (in my hand) whilst still in the car, lock/unlock it worked 2nd time for me. maybe it didn't work on the time(s) you tried. I thought I had to rush, but it seemed to be easy to do, once you had done a 'rehersal' |
10th Jul 2015 1:27pm |
Did you put the key back in the ignition after each key had synced? That may be where I have been going wrong. Will try just doing the ignition thing first and then syncing keys one after the other with button press only. African Bush Junkie ... in London!
10th Jul 2015 1:45pm |
Yes, I just inserted key turned to 1 withdrew clicked each keys buttons, and got a clunk/clunk then did the other, again clunk/clunk, then I just tested them in my hand. (Clunk/clunk.). Then got out and locked it, and it chirped, so to me they were ok, and since then I have used both normally. And I tried doing the button hold and windows down all ok today too.
10th Jul 2015 6:18pm |
All Sorted!
13th Jul 2015 9:59am |
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 |
Deranged Rover
31st Jan 2016 10:53am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
Put one in, then just push the buttons on the other. If you put the second in then you start the procedure again. There is nothing that can't be fixed with a hammer😜😜
31st Jan 2016 10:58am |
Northernmonkeyjones
31st Jan 2016 11:19am |
