Home > Off Topic > Any Plumbers out There?
elbitrevnoc
United Kingdom 2006 Range Rover Vogue SE Td6 Buckingham Blue
I'm throwing myself on the mercy of any Full Fat driving plumbers out there!
I'm afraid plumbing really isn't my subject, but what I believe is the cold water drain cock beneath the basin in my downstairs loo has started leaking this afternoon. I've turned the water off, but can't work out how I disassemble it (I presume it has done sort of washer inside). All I can do us use a spanner to undo the spindle as far as I can, but nothing else. For now I can only do it back up and leave something to collect the leak!
The plumbing us about 20 years old and I've tried to attach a picture for anyone out there that might know than me (which, come to think of it, I'd probably almost anyone reading this!).
Any advice would be much appreciated. I thought it should be something that wouldn't need me to call plumber out for... 2014 3.0 SDV6 Sport HSE Corris Grey with Ebony/Cirrus
GONE - 2012 TdV8 Westminster Orkney/Ivory
GONE - 2012 3.0 SDV6 Sport HSE Luxury Orkney Grey/Ivory
GONE - 2006 3.0 Td6 Vogue SE Buckingham Blue/Parchment
Post #367624 17th Jan 2016 7:46pm
elbitrevnoc
Picture's on its side by the way - drain cock does actually face downwards!!! 2014 3.0 SDV6 Sport HSE Corris Grey with Ebony/Cirrus
Post #367625 17th Jan 2016 7:48pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Turning the spindle out anti-clockwise , sets in into "drain"
From there you can open the spanner up and turn aniticlockwise to screw the guts out .
There should be a sealing washer that you can either replace , or just replace the entire innards from a matching drain valve .
Bear in mind it's soldered in so its better to hold against on the body as you replace the guts of the valve so you don't put too much pressure on the soldered joint and break it .
Post #367627 17th Jan 2016 7:51pm
mzplcg
That looks like a regular 15mm drain cock to me which ought to come undone all the way so the valve drops out. 8mm spanner I think and once you get the middle out it can be re-washered. A new washer is pennies at your local plumbers merchant. If not, you could buy another complete drain cock and swap the middle bits over.
Failing that you would have to replace the unit. Cheap enough but would need to be soldered which again, isn't hard but you would need a decent blowlamp, a heat shield, some flux and some lead free solder. Not in the average toolkit.
Post #367628 17th Jan 2016 7:55pm
The drain cock could be on a mains water pipe or a tank supply pipe.
You need to isolate whichever it is otherwise you stand to get very wet.
You then need a screw-driver which is a good fit in the drain outlet and a spanner or molegrips for the valve stem. You then need to turn the valve stem fully out using the screwdriver to stop the whole thing turning.
I think you may find it is a bit tight. If you can get the innards of the drain cock out you may in the short term be able to remove the washer and refit it upside down for now until you get a replacement.
Post #367630 17th Jan 2016 8:17pm
viper
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
try and break the paint off first as its probably stopping it from undoing. usually there is a small o ring gland in there. Probably easier to buy a new drain valve and just replace the inners
Post #367637 17th Jan 2016 8:41pm
elbitrevnoc
Thanks all - sorted! Just needed a bit of confidence to get some plyers around the end of the o ring. All I need now is a washer..! 2014 3.0 SDV6 Sport HSE Corris Grey with Ebony/Cirrus
Post #367647 17th Jan 2016 9:13pm
vitola231
Canada 2007 Range Rover Supercharged 4.2 SC V8 Santorini Black
wait, wait, wait, Plumbers in UK can afford range rovers? Bow down I�m moving to UK Very Happy
Post #377377 14th Mar 2016 3:53pm
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
lol i use mine as my works car as i can get a fair bit in it and if you fold the seats down a bath fits in nicely L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #377458 15th Mar 2016 9:08am
RR2008HSE
I know, eh. They all seem to have Rols Royces around here. Mr. Green
Post #377670 16th Mar 2016 1:39am
