![]() | Home > Off Topic > Any Plumbers out There? |
elbitrevnoc Member Since: 17 Mar 2010 Location: Berkshire Posts: 150 ![]() ![]() ![]() |
Picture's on its side by the way - drain cock does actually face downwards!!! 2014 3.0 SDV6 Sport HSE Corris Grey with Ebony/Cirrus
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
Turning the spindle out anti-clockwise , sets in into "drain"
That looks like a regular 15mm drain cock to me which ought to come undone all the way so the valve drops out. 8mm spanner I think and once you get the middle out it can be re-washered. A new washer is pennies at your local plumbers merchant. If not, you could buy another complete drain cock and swap the middle bits over.
The drain cock could be on a mains water pipe or a tank supply pipe.
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 ![]() ![]() ![]() |
try and break the paint off first as its probably stopping it from undoing. usually there is a small o ring gland in there. Probably easier to buy a new drain valve and just replace the inners |
Thanks all - sorted! Just needed a bit of confidence to get some plyers around the end of the o ring. All I need now is a washer..! 2014 3.0 SDV6 Sport HSE Corris Grey with Ebony/Cirrus
vitola231 Member Since: 07 Jan 2016 Location: london Posts: 44 ![]() ![]() ![]() |
wait, wait, wait, Plumbers in UK can afford range rovers? |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 ![]() ![]() ![]() |
lol i use mine as my works car as i can get a fair bit in it and if you fold the seats down a bath fits in nicely L322 2008 vogue
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
I know, eh. They all seem to have Rols Royces around here. ![]() |
