Home > Technical (L322) > service reset not working |
No known fault I am aware of.
17th Aug 2017 12:40pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
its just not responding at all pal , the mileage etc pops up as expected but nothing else |
17th Aug 2017 12:45pm |
Does the trip reset work?
17th Aug 2017 4:57pm |
trip works perfectly , I don't think its that pal as I tried it before the other days antics , door open ? hmmmm |
17th Aug 2017 4:59pm |
just been and tried it again with the drivers door open , nada , only thing I can see that changes is where the mileage is shown , that flashes 5 times with the figure -31425 the it returns to the vehicle miles but all of this only happens with the ignition on and not in KLR |
17th Aug 2017 5:07pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 |
Hi,
17th Aug 2017 5:30pm |
I am presuming the flashing -31425 is related to service ?? |
17th Aug 2017 5:40pm |
Yes it's the mileage countdown to, or the number of miles past a service.... ______________________________
17th Aug 2017 6:00pm |
this is odd as the box next to that read out has service - oil service in it but they are not lit , I have a mate with a 525d that refuses to let me reset the 'past service due' even thow I have a main dealer level diag tool |
17th Aug 2017 6:02pm |
There is a bulb behind the service / oil service window, have you checked to see if it's ok..
17th Aug 2017 6:10pm |
well no pal , I had the clocks out the other day for an unrelated matter but did swap a bulb ( not that one) even still , surely the procedure should work wether the wording is illuminated or not ?? |
17th Aug 2017 6:13pm |
Yes it should you're right. How does your ignition feel when you turn the key? Is it a bit sloppy?
17th Aug 2017 6:24pm |
its got no markings on it and no real feeling till I hit ignition pal |
17th Aug 2017 6:27pm |
just tried it again , still nothing , it does the scroll thing when ign is first on but I cant get it to respond to reset at all |
17th Aug 2017 6:35pm |
