Home > Technical (L322) > service reset not working
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
ive tried every method I can find to reset the service indicator on my 52 reg vogue with no joy , is there a known fault with the instrument binnacle that stops it from being performed ??
Post #448109 17th Aug 2017 12:20pm
No known fault I am aware of.
Here is the procedure from the wiki (tried and tested)
Resetting the Oil Service or Service Interval Message 02-<05
Ignition key must be “off”
Press and hold the trip odometer button in the instrument cluster (left button), and turn the ignition key to the first position (KLR).
Keep the button pressed for approximately 5 seconds until one of the following words appear in the display: “OIL SERVICE, or “INSPECTION”, with “reset”.
Release the reset button and press and hold it again until “reset” begins to flash.
While the display is flashing, press the left button briefly to reset the service interval.
After the display has shown the new interval, the following will appear: “END SIA”.
Where for you is it going wrong / not working ? .
Post #448111 17th Aug 2017 12:40pm
bembo449
its just not responding at all pal , the mileage etc pops up as expected but nothing else Confused
Post #448112 17th Aug 2017 12:45pm
Does the trip reset work?
You had the binnacle out the other day? Did it all go back properly? Dislodge something?
and you tried with the door open as well ? .
Post #448152 17th Aug 2017 4:57pm
bembo449
trip works perfectly , I don't think its that pal as I tried it before the other days antics , door open ? hmmmm
Post #448154 17th Aug 2017 4:59pm
bembo449
just been and tried it again with the drivers door open , nada , only thing I can see that changes is where the mileage is shown , that flashes 5 times with the figure -31425 the it returns to the vehicle miles but all of this only happens with the ignition on and not in KLR
Post #448156 17th Aug 2017 5:07pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi,
I had a problem similar to this, my date wasn't set correctly after I changed the battery out. I changed the date and carried out the service reset in the wiki and it worked, well for me anyway....
Good luck ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #448159 17th Aug 2017 5:30pm
bembo449
I am presuming the flashing -31425 is related to service ??
Post #448162 17th Aug 2017 5:40pm
UK Marine
Yes it's the mileage countdown to, or the number of miles past a service.... ______________________________
Simon
Post #448166 17th Aug 2017 6:00pm
bembo449
this is odd as the box next to that read out has service - oil service in it but they are not lit , I have a mate with a 525d that refuses to let me reset the 'past service due' even thow I have a main dealer level diag tool
Post #448168 17th Aug 2017 6:02pm
UK Marine
There is a bulb behind the service / oil service window, have you checked to see if it's ok..
I pulled this from the handbook -
When the starter switch is turned to position ‘I’, a ‘countdown’ to when the next service is due appears in the total distance travelled display (arrowed in inset). A minus sign preceding the distance indicates that the service interval point has been exceeded and this is the distance by which it is overdue.
After approximately five seconds, the display reverts to show just the total distance travelled.
The mileage countdown is controlled by the engine management system and is adjusted to allow for driving style and conditions, to gauge when the appropriate service becomes necessary.
Cheers ______________________________
Simon
Post #448170 17th Aug 2017 6:10pm
bembo449
well no pal , I had the clocks out the other day for an unrelated matter but did swap a bulb ( not that one) even still , surely the procedure should work wether the wording is illuminated or not ??
Post #448171 17th Aug 2017 6:13pm
UK Marine
Yes it should you're right. How does your ignition feel when you turn the key? Is it a bit sloppy?
I'm just wondering if your inadvertently skipping past the 1st position, it's easily done as the barrel isnt the best piece of engineering..... ______________________________
Simon
Post #448175 17th Aug 2017 6:24pm
bembo449
its got no markings on it and no real feeling till I hit ignition pal
Post #448177 17th Aug 2017 6:27pm
bembo449
just tried it again , still nothing , it does the scroll thing when ign is first on but I cant get it to respond to reset at all
Post #448180 17th Aug 2017 6:35pm
