Home > Technical (L322) > Fuel Burning Heater Fault
SingeRRS
MY12 - Fuel Burning Heater keeps cutting out
With the cold snap I noticed the car isn't defrosting with timed climate. Just tried a few experiments turning the FBH on with the remote and on turning on:
1. FBH fan can be heard under NS wheel arch
2. Then fuel pump starts clicking
3. FBH ignites - you can smell the fumes - and fan goes into high power mode - sounds like a jet engine starting up
4. Fuel pump clicks faster
5. Light on climate control fan speed dial in car starts flashing
6. Goes on for about 90 seconds: then
7. High speed fan noise stops and fuel pump stops clicking
8. Light on climate control dial stops flashing
9. Fan goes into low power mode - presumably to cool the FBH down
10. A few minutes later all goes quiet.
Opening and re-locking the car allows the FBH to be started from the remote and exactly the same happens.
Any ideas - it had worked perfectly for three years - car is 3 years and 2 months old!!
Many thanks in advance
Post #366207 9th Jan 2016 11:37am
is the battery ok...might be worth drop testing it to see if it still holds charge.. ... - .- -.
Post #366210 9th Jan 2016 1:21pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
http://www.the75andztclub.co.uk/forum/showthread.php?t=71982
Best diagnostic site for FBH
Nige
Post #366236 9th Jan 2016 4:46pm
EU 29
Did you find out what was wrong? My 57 FFRR TDV8 has precisely the same problem. Unit fine when engine on though, I can feel the hot air pumping out from the small FBH exhaust by the front wheel.
Post #368372 21st Jan 2016 10:39pm
5c0tty
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
I'm having the same issue too, just cuts out when using the remote or timer, seems to run ok with engine running but i can be sure Sad
any help would be great
scotty
Post #368406 22nd Jan 2016 12:43pm
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Gents, check out ,My post FBH Success at last for Ian at Sub Zero Thumbs Up
Post #368724 24th Jan 2016 6:43pm
5c0tty
Hi j evro
where is your post mate, can't find it
scotty
Post #368796 25th Jan 2016 10:17am
J evro
@Scotty
http://www.fullfatrr.com/forum/topic35753.html
He travels most of the country by the sounds of him As he contracts for Ambulances/lifeboats/etc etc
Best give him a call and see what he says
Post #368814 25th Jan 2016 12:16pm
