Home > Maintenance & Mods (L322) > Rear Wiper Issue
miggit
Have you popped the jets off the shaft, as if you were going to remove the arm, and run some wash through the system?
Also with the jets off try an air line on them, I know that when they are blocked, they are really blocked Shocked
A soak in hot water might soften things up too, after all it's mainly dried up screen wash, unless someone's been putting Fairy liquid in the system........... you have a lot of unblocking to do then Thud Yesterday I couldn't spell Engineer... Today I are one!
Post #369352 29th Jan 2016 1:18pm
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
Didn't know you could remove the jets like that, I'll have to give it a try. Do you need to remove the spoiler to get at them? NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #369359 29th Jan 2016 2:28pm
miggit
Yes you do, but that is well easy to do, if you open the tailgate and look at the dirty bit at the top there are 2 x 10 mm bolts (M6 thread) which you need to remove, then shut the tailgate and slide the spoiler towards you (away from car) and it should lift off (key hole slot in spoiler locks on to pegs in top of tailgate).
Then it should just sit on the roof and you can get at the wiper assembly Thumbs Up
Ps, give the wiper arm a good work out with some oil, as they tend to corrode up and hold the wiper off the window Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #369365 29th Jan 2016 2:59pm
