![]() | Home > Maintenance & Mods (L322) > Disable AFS with IIDTool? |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 ![]() ![]() ![]() |
I wonder what your doing |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35528 ![]() ![]() |
why do you want to do that Alan? ... - .- -.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6746 ![]() ![]() ![]() |
That's where I've been looking Rob but I just don't see anything obviously related to the AFS settings.
so you want to stop them from moving side to side i gather...i dont think anything in the ccf will do that only a wire disconnection will.. ... - .- -.
no he needs to do what I am doing and deactivate the ccf from thinking it has AFS, this stops the warning light in the dash, which when the lights are not connected flashes constantly.........
hot and cold monitoring only stops bulb errors...i cant see anything in the ccf to stop the lights moving.. ... - .- -.
its not in the normal CCF option list Stan, its in the untested version of optional settings, as the saying goes dont play if your scared to toast an ECU as once its gone it dead! |
whats this ''the untested version of optional settings'' then.. ... - .- -.
It's what you get when your a beta tester |
Just need the delivery of my bloody headlights so I can put the car front back together!!! |
Very strange, as I'm also a beta tester and I've not seen any different options |
Because my AFS light with no lights connected was flashing, and now that I have disabled it as not fitted, I don't get the check light or any faults from the module ecu |
So which revision of the IIDTool s/w do you have? Got - 2017 SDV8 Autobiography in Loire Blue
Latest firmware from gap website and current 2006- L322 software 3.00.00 B2134 release |
