![]() | Home > Maintenance & Mods (L322) > Scary Moment |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 507 ![]() ![]() ![]() |
Very considerate |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8533 ![]() ![]() ![]() |
Oh dear, think I upset someone.... |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Not at all, i'm just concerned that you appeared to take offence to my perfectly civil comment. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
Not sure about the fastrack but many tractors and probably the fastrack have 'powered steering' and not PAS.There is no mechanical linkage but purely hydraulic,the steering wheel operates directly to a hydraulic block,can be fun on a very cold morning when it does not work well until the oil has warmed up ,usually has a warning sign !! |
After that long post you must be in as bigger 'tizzy' as the rest of us. ![]() It's not really an issue if the law is out of date or not, all the while the law is there manufacturers have to keep fitting handbrakes (and you're supposed to apply it, just like you're not supposed to do 80mph on the motorway) - the day the law is repealed will be the day manufacturers stop fitting handbrakes (to save money more than anything). I put mine on out of habit, i've either had manual cars or automatic lorries (where you really do have to put the handbrake on - they don't have P) But you're right, i don't see what all the fuss is about. The question was asked what the point of having a hand brake is, and i calmly and non-judgementally gave the point of them being there - ie. it has to be there and be used by law. There are also other times when they might be useful, as Stan pointed out, it makes it easier to get it into gear on steep hills. Brake failure is pretty rare these days, but as i said in my original post yanking the handbrake on is better than nothing obviously the faster you're going the less effective it is. I suppose on most Auto's these days too there's not mechanical linkage for the gear selector, so an electrically failure could 'possibly' result in not being able to put it in park or it unlocking it's self (unlikely, but possible) |
Yeah Fork lifts are the same i think. You do have a certain amount of steering with the power off, but it's not good! You're basically manually pumping fluid into the steering rams. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
as requested by the OP and because its gone off topic, i'm now locking this thread... ... - .- -.
