![]() | Home > Technical (L322) > ECU? Fan running constantly - behind offside headlight |
It is the fan in the big black box full of ECUs. This is a known problem well covered on the forum in the past. Search is your friend |
rrsimon Member Since: 03 Oct 2015 Location: Hitchin Posts: 45 ![]() ![]() ![]() |
Blank. |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Does your car go to sleep.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
First try a battery reset sir... Cures all number of issues |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
@miggit - well I never knew that |
Err, Not only is it a 2 wire jobbie, but it is also threaded, like a water one on the head, and then just poked in to a plastic clip |
Blank. |
The fan defiantly runs when the key is out, but as the ECU's go to sleep I can't see the temp going up, but, I would not recommend running the car without the fan, god knows that the ECU's are temperamental enough, without overheating them....... that could be a very costly mistake |
Just had a look at the wiring, the fan is powered directly from the sensor, which is in turn powered directly from the BCU, from what I can see there is no fuse between the components, so the easy kill is out of the question. Looking at the way it is wired the only thing that can cause the fan to run constantly is the temperature sensor, it must have failed in the "on" position. I will have a dig around and see if I can find the temp range that it operates within, there is a good chance that an after market one will do the job |
Blank |
