Home > Technical (L322) > ECU? Fan running constantly - behind offside headlight
rrsimon
England 2003 Range Rover Vogue Td6 Adriatic Blue
Blank.
Post #361332 9th Dec 2015 8:05pm
It is the fan in the big black box full of ECUs. This is a known problem well covered on the forum in the past. Search is your friend Thumbs Up .
Post #361365 9th Dec 2015 9:47pm
rrsimon
Blank.
Post #361376 9th Dec 2015 10:05pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Does your car go to sleep.
Park up, lock car, see red light on gearstick selector (centre console) is on.
Return to car in about 15 minutes - red light should be off. FF is now sleeping.
Reading it a bedtime story is no help if it is still awake.
. Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #361404 9th Dec 2015 11:27pm
First try a battery reset sir... Cures all number of issues Thumbs Up
Post #361406 9th Dec 2015 11:29pm
miggit
Whistle I think that I might know the cause Wink
I was in the ECU box the other day on a pals ffrr changing the injector harness.......... and I noticed that there was a temp sender clipped in to the upper half of the box nearest to the windscreen........ didn't think much about it until now, just had a look on Microcat and it says Dah! Sensor ECU Temp Thumbs Up
Part Number YWL000030 and is around £15, that would be my first port of call, if that doesn't do it then I'd be looking at the wiring to that sensor for a short, Good Luck Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #361408 9th Dec 2015 11:32pm
Thumbs Up Bow down Good call Miggit Bow down Thumbs Up
Post #361410 9th Dec 2015 11:38pm
SMUTT
@miggit - well I never knew that Bow down - useful info thanks. Bow down
If it is just a 2 wire thermostat (he laughs uncontrollably at thinking such a simple device may be fitted) I suppose (if you are confident about the way it works) you could always try disconnecting or shorting it out depending if it is normally closed or normally open contact. Howard
Post #361413 9th Dec 2015 11:47pm
miggit
Err, Not only is it a 2 wire jobbie, but it is also threaded, like a water one on the head, and then just poked in to a plastic clip Shocked Not very custom fit Evil or Very Mad but on the up side it's obviously cheap and nasty so they can't over charge Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #361415 10th Dec 2015 12:00am
rrsimon
Blank.
Post #361448 10th Dec 2015 7:57am
miggit
The fan defiantly runs when the key is out, but as the ECU's go to sleep I can't see the temp going up, but, I would not recommend running the car without the fan, god knows that the ECU's are temperamental enough, without overheating them....... that could be a very costly mistake Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #361457 10th Dec 2015 9:11am
miggit
Just had a look at the wiring, the fan is powered directly from the sensor, which is in turn powered directly from the BCU, from what I can see there is no fuse between the components, so the easy kill is out of the question. Looking at the way it is wired the only thing that can cause the fan to run constantly is the temperature sensor, it must have failed in the "on" position. I will have a dig around and see if I can find the temp range that it operates within, there is a good chance that an after market one will do the job Thumbs Up
In the meantime I would suggest unplugging the sensor to see what happens.... if it stays on then you have a short in the wires within the ECU box, that would be cured by following the wire from the sensor to the fan in the bottom on the box, but if the fan stops then it's the sensor, but I wouldn't run without the fan, might end in Big Cry Yesterday I couldn't spell Engineer... Today I are one!
Post #361459 10th Dec 2015 9:18am
miggit
Banging Head Banging Head while these are common s/h there aren't any mainstream outlets selling them Banging Head Banging Head
You could try a call to these chaps https://www.britishparts.co.uk/ and quote part number YWL000030, or failing that there is always the local stealers..........
OR, you could try BMW, you might be surprised... there main parts store is in Northampton, so Herts Beds and Bucks get same day parts deliveries Thumbs Up the Sensor is used in just about every BMW ECU box and has 1741900 BMW35C stamped in it, so they should be able to work it out from that Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #361465 10th Dec 2015 10:02am
rrsimon
Blank
Post #361500 10th Dec 2015 11:27am
miggit
Post #361504 10th Dec 2015 11:49am
