Home > General > What will a ffrr carry in its rear?
Andy
I have 50 bags of hardcore that I need to transport a short distance. They weigh 20Kg each. How many can I put in the back without causing damage or overloading?
TIA
Post #358415 23rd Nov 2015 10:20pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
DVDs or magazines? Just curious! 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #358416 23rd Nov 2015 10:22pm
Laughing @skot
Just for practical purposes sounds like 4 to 5 trips for me .
Post #358417 23rd Nov 2015 10:24pm
I'd do it in 2 Thumbs Up
I weigh 100kg and would be happy with 3 of me in the back plus another 200kg in the boot
Maybe 3 trips if you're a wuss Whistle
If they are open top bags, then basically as many as you can fit in the floor space Thumbs Up
Post #358422 23rd Nov 2015 10:32pm
SKOT wrote:
Just curious!
You can get DVD’s for that too sir Shocked
Laughing Laughing Laughing Bow down Thumbs Up
Post #358423 23rd Nov 2015 10:42pm
Basilfawlty
England 2016 Range Rover Autobiography SDV8 Corris Grey
Wish I'd thought of that Big Cry
Post #358424 23rd Nov 2015 10:43pm
CS
Going by the brochure I have the TD6 has a gross vehicle weight of 3,050kg and weighs 2,570kg, so it is rated to carry 480kg. Deduct your weight from 480kg, divide by 20 and then see if the number of bags produced by that calculation will fit. The tyres will need to be at a higher pressure, per chart on driver's door frame if the car is fully loaded.
If you have a towbar the best thing would probably be to borrow or hire a trailer, which would be easier, quicker and cleaner and should be less effort to load/unload too. Only Range Rovers since 1988
Post #358548 24th Nov 2015 8:27pm
As above, cheap trailer and job done.
You could push the limit by not having a full tank of fuel, each 1/4 of a tank you drop is another bag of hardcore.
If it's 10miles or less on quiet roads you could get away with 2 trips but would be pushing it to the limit. Also don't forget it's not just weight but size.
The boot floor is something to consider as well, the spare wheel cover isn't the strongest thing in the world so maybe worth some plywood on top to protect carpet and floor. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #358558 24th Nov 2015 9:32pm
Are you buying or removing the hardcore?
If you are buying it why not just get it from a merchant and get it delivered?
If you are getting rid get a yellow skip bag from a merchant and put it in there then call the number on the bag and someone will collect Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #358664 25th Nov 2015 12:59pm
Rangeyman
I certainly will not be stacking mine with hardcore.The craziest overload I saw was when my brother put a Jcb engine in the back of his Fiesta and drove it back from Bradford,the car was scraping the floor !!
Post #358775 25th Nov 2015 7:18pm
johnboyairey
fold the rear seats double, and use a decent few old sheets, get the load over the axle, and up against the seats. this will greatly help the load to be spread. it will be safer too in an emergency. a bit extra work, will save you a trip or two. i have had engines, concrete, 6 dustbins half full of earth etc. huge sawn 2ft wide logs, all sorts. currently i have a jag mk2 iron block 6 pot engine in the boot area, its fine. ie seats down. my suspension works perfect too.
it would be wise to avoid the speedbumps routes though.
Post #358781 25th Nov 2015 7:29pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
..."What will a ffrr carry in its rear?"....
Can't resist - well standard Range Rover gear really - a couple of bodies .. shotgun ... tarpaulin and rope etc Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #358786 25th Nov 2015 7:36pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Dont forget tiewraps Rolling with laughter
Post #358789 25th Nov 2015 8:22pm
Worst that can happen is the air pump or a pipe or bag gives way with the required higher pressures to keep it at height.
I've had just a smidge under 3m' of wood in the back of my XM and dont get me wrong it was slower than normal for braking and accelerating but the beauty of hydro is that the ride gets more supple with more weight on it Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #358915 26th Nov 2015 12:42pm
comports
Just be careful and think about it - Is 1 extra journey really that bad (depends on the distance)
I loaded my first FF up at tops tiles once. enough tiles do do the whole bathroom, loads of tile cement and grout plus boards for the floor - Didn't seem to take up too much room but took ages to pump up and level. I think I wore the compressor out with it continuously pumping and from that day onwards was really lazy to inflate.
Lesson learnt though..... Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #359052 26th Nov 2015 6:28pm
