![]() | Home > General > What will a ffrr carry in its rear? |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2943 ![]() ![]() ![]() |
I have 50 bags of hardcore that I need to transport a short distance. They weigh 20Kg each. How many can I put in the back without causing damage or overloading?
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
DVDs or magazines? Just curious! 2006 4.2 SC
You can get DVD’s for that too sir ![]() ![]() ![]() ![]() ![]() ![]() |
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 655 ![]() ![]() ![]() |
Wish I'd thought of that ![]() |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1392 ![]() ![]() ![]() |
Going by the brochure I have the TD6 has a gross vehicle weight of 3,050kg and weighs 2,570kg, so it is rated to carry 480kg. Deduct your weight from 480kg, divide by 20 and then see if the number of bags produced by that calculation will fit. The tyres will need to be at a higher pressure, per chart on driver's door frame if the car is fully loaded.
As above, cheap trailer and job done.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Are you buying or removing the hardcore?
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
I certainly will not be stacking mine with hardcore.The craziest overload I saw was when my brother put a Jcb engine in the back of his Fiesta and drove it back from Bradford,the car was scraping the floor !! |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
fold the rear seats double, and use a decent few old sheets, get the load over the axle, and up against the seats. this will greatly help the load to be spread. it will be safer too in an emergency. a bit extra work, will save you a trip or two. i have had engines, concrete, 6 dustbins half full of earth etc. huge sawn 2ft wide logs, all sorts. currently i have a jag mk2 iron block 6 pot engine in the boot area, its fine. ie seats down. my suspension works perfect too.
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
..."What will a ffrr carry in its rear?"....
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
Dont forget tiewraps |
Worst that can happen is the air pump or a pipe or bag gives way with the required higher pressures to keep it at height.
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1749 ![]() ![]() ![]() |
Just be careful and think about it - Is 1 extra journey really that bad (depends on the distance)
