![]() | Home > Maintenance & Mods (L322) > TRANSFER CASE OIL FFRR |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 354 ![]() ![]() ![]() |
Hi
Parts: IYB500020 - Drain Oil Plug @ � 2.35 IYF500030 - washer @ � 0.54p You can source the oil for around �24.00 But who know exactly what grade of oil is it ? Castrol ? Grade ? 75W - 90 ??? I ve got a complete LR workshop manual - but at the moment I cant find it in here as its 3500 pages both cars are 4.4 TDV8 - 12 year models Thanks in advance Just found this if it helps anyone: http://www.disco3.co.uk/gallery/albums/use...ations.pdf more info: http://www.disco3.co.uk/forum/topic10978.html Got to the bottom of this It pays to know top people in certain companies - called the head guy I know who has confirmed: Shell TF0753 is the same as: Castrol BOT26 FMB1 Fully Synthetic Transfer Case Oil GRADE OF OIL IS: SAE 75W90 API GL4 suggest you check on all this yourself and research it too - but I am happy with my results again - hope this helps anyone reading it Last edited by EmiratesA380 on 3rd Nov 2015 6:40pm. Edited 2 times in total |
Hey Zirconblue
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
no problem, the picture above is just a generic one, the actual bottle was a castrol 1ltr one (all be it trade/industrial labelled rather than flashy retail labelling) in a land-rover box.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Yep - Just buy it from dan, wasn't that much tbh when I changed mine a few years back.
Zirconblue
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 124 ![]() ![]() ![]() |
Purchased my transfer box oil today from advanced. Just wondering if anyone knows the amount needed, the bottle I got contains 946ml which I'm told is enough. I don't want to end up being short. |
From memory it require around 1.3 litres I think |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35656 ![]() ![]() |
John is kinda right
but i dont think you will get all the oil out so maybe your amount will be enough Gary.. ... - .- -. Y. O. L. O. . |
Thanks Stan. I will let you know how I get on. |
ryan did his 4.2 and 1.3 litres came out,
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
You will need more than 1 litre I'm afraid. |
Thanks guys. I've just ordered another 1L tub. |
Earlier ones are only 1ltr fill from dry or 0.96ltr refill.
Advanced Factors Site Sponsor Member Since: 31 May 2013 Location: Southampton Posts: 198 ![]() ![]() |
If you look at our website we list oil grades and quantities in the service item section for each model.
