Home > In Car Electronics (L322) > Remote Climate Heater in my MY11
Markbhai
England 2006 Range Rover Vogue Td6 Buckingham Blue
Hi
I ahve just bought a MY2011 L322 and have an issue with the remote diesel heater. When I press the remote on switch the green light flashes for about 2 seconds and then stops, the heater doesnt switch on.
I have had the car battery checked at Halfords and they say it is OK (readings below) and I have also changed the batteries in the remote.
Does anyone have any 'easy checks' before I take the car to the stealership?
Battery readings:
12.45v
790 EN (A) - Measured
850 EN (A) - Rated
Starter Test
Cranking 11.67v
Charging Test
No Load 14.77v
Load 14.75v
Rated - Good Battery
Regards
Mark.
Post #358067 22nd Nov 2015 11:36am
Try searching for FBH
Fuel Burning Heater
When did you test it - as it needs to be cold enough to operate ?
Can you turn it on manually from the dash ? i.e. is i the heater or remote that is a problem ?
Post #358068 22nd Nov 2015 11:43am
