Home > Maintenance & Mods (L322) > Blocked sunroof drainage duct (I think!)
Snowflopsy
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Epsom Green
Hi all, I have no technical knowledge so please be gentle. Having done so very low level investigation, it would appear that the drivers side drainage duct(?) is blocked inside the sunroof. Would some blowing through a piece of pipe (say some plastic fish air filter piping help flush it through or do I need to take it to a mechanic type person?
Many thanks for your anticipated help and if you could keep any answers as low tech level as possible I would be very grateful as my usual level is to take it to my mechanic and say "you do it" but since buying my utterly beautiful but inordinately gas guzzling 4.2 rr sport supercharged I have decided to try and be more proactive!
Post #357960 21st Nov 2015 4:32pm
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
I have had similar and yes of course any soft pipe is worth a go. If you hit a blockage then something stiffer may be needed such as copper wire etc.
I as soon as I felt something give ran water down the hole to wash it all through.
Unsure on sun roof but I wouldn't use any hard wire as some drains are made from soft materials and you may rip same.
Also once I managed to fire the hose straight into a hole and blew the blockage through but the back wash was messy so no good for a sun roof he he Many thanks
Paul
Post #357967 21st Nov 2015 4:52pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Have a look at this thread.
http://www.fullfatrr.com/forum/topic33664.html
And this
http://www.fullfatrr.com/forum/topic14068....roof+drain
Post #357972 21st Nov 2015 5:36pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
I did read that someone had a blockage which they tried to shift with wire - no luck - also forcing something down the pipe (wire / compressed air) may cause a joint to become disconnected (and thereby a bigger problem than when you started )
Th solution they ended up with was squirting wd40 down the line - left to soak then the blockage cleared with some water poured down Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #357986 21st Nov 2015 7:26pm
