Home > Maintenance & Mods (L322) > Blocked sunroof drainage duct (I think!) |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 |
I have had similar and yes of course any soft pipe is worth a go. If you hit a blockage then something stiffer may be needed such as copper wire etc.
21st Nov 2015 4:52pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1254 |
Have a look at this thread.
21st Nov 2015 5:36pm |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
I did read that someone had a blockage which they tried to shift with wire - no luck - also forcing something down the pipe (wire / compressed air) may cause a joint to become disconnected (and thereby a bigger problem than when you started )
21st Nov 2015 7:26pm |
