![]() | Home > Technical (L322) > Power steering gone heavy |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8568 ![]() ![]() ![]() |
Mine doesn't make any humming noise when I turn the wheel... maybe yours was telling you something!!!
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Servotronic is the most likely faulty item and usually the first to be changed |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I think I had a similar fault. I was trying to wire in a dash cam, and chose what I thought was a suitable fuse to piggy back from. Got the cam working, but found that steering was then much heavier. Like you thought I had a direct issue, I disconnected it, and problem went.
John, he said he checked the fuse.... I thought if the servotronic gave up you lost all the assistance... I could be wrong though, mines never had a problem (that's jinxed it) Pete
Zain Member Since: 17 Apr 2014 Location: London Posts: 98 ![]() ![]() ![]() |
Cheers for the comments....
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2688 ![]() ![]() ![]() |
I've a servotronic valve for sale if needed. |
UPDATE: Each time the car is started now (after being switched off for a few good hours) i can feel a momentary judder through the steering wheel as i turn it for the first time (when moving off). During this phase (which lasts about 5-10 seconds) the steering is very heavy. It then lightens up slightly to what feels like only 50% power assisted steering.
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 341 ![]() ![]() ![]() |
Hi Zane,
UPDATE: been driving around with the power steering/juddering problems and then something really odd happened today on start up.......no juddering and it was back to 100% PAS....normal featherlight steering!
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
blackstoun Member Since: 22 May 2015 Location: Scotland Posts: 116 ![]() ![]() ![]() |
I had a similar issue of humming noise when turning the wheel
damn spell checker
There is an edit button over here somewhere..................................................................................................^^^^^^^ Pete
Blackstoun.......that would very much be appreciated if you could.
