Home > Technical (L322) > Power steering gone heavy |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8199 |
Mine doesn't make any humming noise when I turn the wheel... maybe yours was telling you something!!!
18th Nov 2015 5:01pm |
Servotronic is the most likely faulty item and usually the first to be changed |
18th Nov 2015 5:16pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
I think I had a similar fault. I was trying to wire in a dash cam, and chose what I thought was a suitable fuse to piggy back from. Got the cam working, but found that steering was then much heavier. Like you thought I had a direct issue, I disconnected it, and problem went.
18th Nov 2015 5:18pm |
John, he said he checked the fuse.... I thought if the servotronic gave up you lost all the assistance... I could be wrong though, mines never had a problem (that's jinxed it) Pete
18th Nov 2015 5:43pm |
Zain Member Since: 17 Apr 2014 Location: London Posts: 98 |
Cheers for the comments....
18th Nov 2015 10:10pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2643 |
I've a servotronic valve for sale if needed. |
18th Nov 2015 10:38pm |
UPDATE: Each time the car is started now (after being switched off for a few good hours) i can feel a momentary judder through the steering wheel as i turn it for the first time (when moving off). During this phase (which lasts about 5-10 seconds) the steering is very heavy. It then lightens up slightly to what feels like only 50% power assisted steering.
19th Nov 2015 10:35pm |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 338 |
Hi Zane,
20th Nov 2015 8:32am |
UPDATE: been driving around with the power steering/juddering problems and then something really odd happened today on start up.......no juddering and it was back to 100% PAS....normal featherlight steering!
26th Nov 2015 6:30pm |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4994 |
All my spelling errorz are belong to me!
26th Nov 2015 6:44pm |
blackstoun Member Since: 22 May 2015 Location: Scotland Posts: 116 |
I had a similar issue of humming noise when turning the wheel
26th Nov 2015 8:03pm |
damn spell checker
26th Nov 2015 8:04pm |
There is an edit button over here somewhere..................................................................................................^^^^^^^ Pete
26th Nov 2015 10:49pm |
Blackstoun.......that would very much be appreciated if you could.
27th Nov 2015 5:07pm |
