![]() | Home > LPG > Anyone run an 4.2sc on LPG here? |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
A pal of mine bought one with the Prins system, he's been very pleased but in the summer if he drives it hard it gets very hot... Is this where I put the car details and a bit about myself ?........ |
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
hmmmm should it do that even if he drives it hard? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1361 ![]() ![]() |
I have an lpg system in mine
I should explain really; I didn't mean like a bank robber ! He tows a pretty heavy boat and heads down to Spain each year, both times he's done that run it has become very hot. A combination of a heavy load, outdoor temp and longer driving spells have likely contributed as a combination. He's selling it now anyway and making his way to the heavy oil division with a 4.4 tdv8 ! Is this where I put the car details and a bit about myself ?........ |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8490 ![]() ![]() ![]() |
LPG burns about 10 degrees hotter than petrol, but seeing as they both burn around 1000 degrees it doesn't make much difference, it certainly won't be the LPG's fault it runs hotter unless it's been poorly set up and is running lean but that would usually put the MIL light on...
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
I've a bmw engined 4.4 V8 with a Prins system. Never had any problems at all in the 3+ years and 35k miles i've owned it. It came with a certificate of installation.
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
I have a 4.2 with the Prins system. I get it serviced regularly and have the lube system.
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
I run my SC on LPG no problems, the car was converted before i bought it and has now covered 40000 on log with no problems. I have the Romano system which works really well, is setup to introduce petrol at high rpm as well. |
Laurence82 Member Since: 17 Jul 2022 Location: Lancaster Posts: 2 ![]() ![]() ![]() |
I have read that pre 2006 when they changed the supercharged engine to nickel the valves are hard.... |
Yours, being a 2005 is one of the first S/C and could be a 2006 Model Year car... |
Still here 7 years later running mine on lpg |
Forgot to mention now slipstream of petrol at 2950 rpm, Im getting older and don't thrash it as much |
so was there a pre nickel engine that was less prone to valve damage? the guy I bought the car off said the LPG did feed some petrol in with the LPG I thought it was bogus so all good there if its a real thing. excellent.
