Home > In Car Electronics (L322) > Help Fault Coads
Ziggy
Australia
Help Fault Coads
Right a bit of background, TV has not worked since bringing the car Oz.
Been playing around with the BT IID Tool for ages still no go
so has anyone seen these faults before and should I be concerned what does it all mean......
IPC-Instrument Pack
• U0248-87 (2F) Lost communication with remote driver utility module - Bus signal/message failure - missing a message
TMC-Traffic Message
• B1A56-18 (2F) Antenna circuit - General electrical failure - circuit current below threshold
TVM-Television
• B1A00-48 (2F) Control module - System internal failure - supervision software failure
AAM-Audio Amplifier
• B1A02-13 (2F) Speaker 2 circuit - General electrical failure - circuit open
• B1A01-13 (2F) Speaker 1 circuit - General electrical failure - circuit open
BPM-Body Processor
• 0x58 Crash-sensor continuously active
IPC-Instrument Pack
LCM-Light Control
• 0x003C Unknown
TMC-Traffic Message
• B1A00-4A (2F) Control module - System internal failure - incorrect component installed
TVM-Television
Now I'm OK with the spanners and a hammer but a bit of a neanderthal when it comes to the smoke in the box
stuff
I'm guessing the B1A00-48 (2F) might have something to do with it but what is it and can I fix it with my hammer
Thanks
Ziggy "Those who cannot remember the past are condemned to repeat it."
George Santayana
Puts away his cloth cap and donkey jacket
Goes and sits in the naughty corner
Post #356597 13th Nov 2015 6:59am
ebajema
 MY 2010 5.0 SC Galway green and sand interior!!
Post #356599 13th Nov 2015 7:39am
ebajema
Sorry mate, couldn't resist the smoke in box remark Smile.
As for the faults, first I'd say reset all the faults and then see if any return when you check after a while.
Also have a look in the leftside rear compartment and look for wateringress or traces of old water ingress. Then check all connectors, wiggle them to see if there is something loose or the likes.
Hope this is a start Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #356600 13th Nov 2015 7:42am
i agree with eugene, clear all the faults as some could be historical then see what you have next time you read the ecu's. ... - .- -.
Post #356606 13th Nov 2015 8:57am
Generic faults , I get some similar or identical faults . Nothing to see here move along folks Very Happy 2008 MY Supercharged
Post #356610 13th Nov 2015 9:19am
Ziggy
Australia
ebajema wrote:
No worries cobber, I have a whole box of that stuff.........still haven't figured out how to get it all back in though
Axle so does your TV work over here?
I have un-plugged and plugged all the leads I an find in the left hand side also its as dry as a bone in there
no sign of any water ingress
Zigg "Those who cannot remember the past are condemned to repeat it."
George Santayana
Post #356632 13th Nov 2015 11:18am
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
The TMC traffic message fault - low current is permanently on my car, you can clear it but it comes straight back, doesn't seem to be causing any issues though Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #356800 14th Nov 2015 12:51am
My TV is fine , have you set it to AUS in the menu ? TMC doesn't exist here nor RDS for that matter so nothing to bother with ,open circuit to speaker is common to most cars along with the other faults they are just glitches in the matrix . Funnily enough my TMC worked in the UK but since setting the car for Australia my iiD says component not fitted as well . 2008 MY Supercharged
Post #356822 14th Nov 2015 4:13am
Ziggy
Australia
Axle when you
say the menu do you mean the one on the touch screen or one in the CCF
I keep changing the one on the touch screen and next time I look its gone back to UK
which receiver in the CCF have you got yours set to?
George Santayana
Post #356826 14th Nov 2015 7:14am
I'll have to check but i'm just off out , will get back to you👍
But when you select Aus on the touch screen it should stay , are you pressing the "OK" button as well ? I seem to remember there is a reason it keeps going back to the original setting . 2008 MY Supercharged
Post #356846 14th Nov 2015 10:31am
