Home > General > A bit of poor design I believe
scanner
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
I picked up my lovely 2010 vogue at the weekend, and then embarked on the three week high intensity 'what do all the knobs and twiddly bits do?' course. Should end up with a PhD at the end of it I believe Laughing
Monday was brilliant sunshine when I took it out for a spin, and a design failing immediately became obvious.
In bright sunshine it becomes impossible to read the touch-screen. It is especially bad with all the finger marks on it. In my previous Beemers the screen is set back quite a way in to the facia, so it is always shaded, so this problem rarely occurs.
If Landrover are reading please take note.
Also I'm not convinced on the whole touch screen proposition as opposed to a knob near the gear selector, however as there is little room for one I can see why they went the TS route. I'm sure I will be used to it by the end of my course. Confused
Post #33713 26th Oct 2010 8:49am
congrats on your new acquisition Thumbs Up , but is there maybe a contrast setting that might make the screen more easier to see.. ... - .- -.
Post #33717 26th Oct 2010 9:06am
iT LAD
failing that, see specman... he will sort you out with some nice shades. should do the trick. Thumbs Up
Post #33719 26th Oct 2010 9:22am
Fox
It a bit of a desgn problem, I've noticed the same in mine.
Reflection of the sun on the touchscreen renders it unreadable until you shield it with your hand.
Fortunately it doesn't happen too often.
Post #33720 26th Oct 2010 9:24am
scanner
I suspose the other option is to wash my hands weekly instead of monthly. Rolling with laughter
Post #33777 26th Oct 2010 2:32pm
DMRR
Or get tints .... Btw, what is this nonsense about being able to spot the diff between factory and non? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #33789 26th Oct 2010 4:12pm
iT LAD
Did someone mention tints.... Laughing
Post #33815 26th Oct 2010 4:47pm
love mine..... ... - .- -.
Post #33816 26th Oct 2010 4:49pm
DMRR
I have got tints on mine, they are not factory but they match my factory ones from the last car, so I guess it is down to the skill of the fitter..... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #33824 26th Oct 2010 5:06pm
Your other Sig was better scarey ............. Whistle
Post #33829 26th Oct 2010 5:31pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Must say I checked my touchscreen in full sunlight and it was very visible, did you try to adjust the brightness from the screen menu? Even if I set it at -3 it is bright enough…
Post #34010 27th Oct 2010 3:38pm
i concur master mick..... ... - .- -.
Post #34011 27th Oct 2010 3:42pm
scanner
The problem only showed itself when the sun was shining in the passenger window at a lowish angle. That way it reflected off the screen front and finger prints and swamped the screen illumination.
Post #34014 27th Oct 2010 3:58pm
iT LAD
It's not about the match, it's about the heating elements... Personal taste though... Thumbs Up
Post #34020 27th Oct 2010 4:24pm
DMRR
Will take some pics, don't understand what your are saying.... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #34026 27th Oct 2010 4:52pm
