Home > Finance, Insurance & Warranties > Extended Warranty
philmc79
United Kingdom 2008 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Extended Warranty
Has anyone got any information as to what is not covered in Land Rovers extended warranties after the 3years Mf warranty has expired
Post #354608 29th Oct 2015 4:51pm
exalin
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Lots of info so I've split it into separate posts to make them a bit more readable...
There are two types of warranty available.
The Extended Warranty covers the majority of mechanical and electrical components originally covered by the manufacturer warranty. Components are covered for mechanical or electrical breakdown, which is the failure of a component, resulting in the sudden stoppage of its function, for a reason other than wear and tear, normal deterioration or negligence.
Consequential damage is also included, this protects against the failure of a non-covered mechanical or electrical component as a consequence of failed mechanical or electrical component covered by the warranty.
It is available for cars which are under 10 years old and have covered less than 100,000 miles at the time of warranty purchase.
The Select Extended Warranty provides cover for most major repairs for mechanical or electrical failure on specific named components.
It is available for cars which have covered less than 100,000 miles at the time of warranty purchase.
Post #354655 29th Oct 2015 11:25pm
exalin
Covered by the Extended Warranty:
    Air Conditioning
    Audio and In-Car Entertainment Systems
    Brakes
    Clutch
    Consumables
    Cooling System
    Differential
    Driveline
    Driveline Couplings
    Electrics
    Engine
    European Cover
    Final Drive
    Fuel System (petrol/diesel)
    Gearbox
    Manifolds
    Propshaft
    Sat Nav
    Steering
    Sunroof
    Suspension
    Transfer Box
    Transmission
    Turbo Unit incl. Intercooler
    Wheel Bearings
    Unlimited Maximum Warranty Claim Liability (up to the price paid for the vehicle in aggregate)
    MOT Insurance
    Land Rover Assistance (optional)
Significant exclusions and limitations to the Extended Warranty:
    Normal maintenance services and the replacement of such items as, but not limited to, spark plugs, plug leads, oils, filters, lubricants and factory fitted accessories.
    Component failure resulting from accidental damage, misuse, neglect, overloading or abnormal use.
    Faults resulting from the use of contaminated fuel or inappropriate fuel for the vehicle.
    Damage which has resulted from a failure to arrange for an obvious fault to be rectified.
    Damage which has occurred as a result of any accessory being fitted (unless the accessory is approved by the manufacturer for use on the vehicle and fitted according to instructions provided by the manufacturer of the accessory).
    Any damage caused by frost, including damage where a lack or failure of anti-freeze has been a contributory factor.
    Any damage or losses to components that are not directly covered within the terms of this warranty.
    The gradual reduction in operating performance (wear and tear) consistent with the age and mileage of the vehicle.
    Any loss, damage or failure which occurs while the vehicle is outside the geographical territories.
    All damage and repairs resulting from water ingress, for example, through damaged or ineffective door, window or roof seals, through doors or sunroofs left open, or caused by flood water.
    Any routine component adjustment and alignment.
    Vibrations and noises related to the operation of the vehicle.
    Deterioration such as discolouration, alteration or deformation of parts due to normal ageing.
    The consequences of repairs, conversions or modifications carried out by firms not approved by the manufacturer, and also the consequences of converting the vehicle to run on LPG.
    Damage resulting from the use of fluids or parts other than original parts or those of equivalent quality.
    Faults that existed prior to the commencement of the warranty.
    Any vehicle used for hire or reward such as taxis or driving schools.
    Any vehicle that is owned by a motor trader or garage or associated companies or by the proprietor(s) of such motor trader or garage.
Post #354656 29th Oct 2015 11:25pm
exalin
Covered by the Select Extended Warranty:
    Air Conditioning
    Braking System
    Casings
    Clutch
    Consumables
    Cooling System
    Differential
    Driveline
    Electrics
    Engine
    Fuel System
    Gearbox
    Oil Leaks
    Steering
    Suspension
    Turbo Unit/Turbo Actuator
    £3,000 inc VAT Maximum Single Claim Liability (unlimited number of claims and value of claims up to the price paid for the vehicle in aggregate)
    MOT Insurance
Other significant exclusions and limitations are the same as for the Extended Warranty (see above post).
Post #354657 29th Oct 2015 11:26pm
