Covered by the Extended Warranty:
Air Conditioning
Audio and In-Car Entertainment Systems
Brakes
Clutch
Consumables
Cooling System
Differential
Driveline
Driveline Couplings
Electrics
Engine
European Cover
Final Drive
Fuel System (petrol/diesel)
Gearbox
Manifolds
Propshaft
Sat Nav
Steering
Sunroof
Suspension
Transfer Box
Transmission
Turbo Unit incl. Intercooler
Wheel Bearings
Unlimited Maximum Warranty Claim Liability (up to the price paid for the vehicle in aggregate)
MOT Insurance
Land Rover Assistance (optional)
Significant exclusions and limitations to the Extended Warranty:
Normal maintenance services and the replacement of such items as, but not limited to, spark plugs, plug leads, oils, filters, lubricants and factory fitted accessories.
Component failure resulting from accidental damage, misuse, neglect, overloading or abnormal use.
Faults resulting from the use of contaminated fuel or inappropriate fuel for the vehicle.
Damage which has resulted from a failure to arrange for an obvious fault to be rectified.
Damage which has occurred as a result of any accessory being fitted (unless the accessory is approved by the manufacturer for use on the vehicle and fitted according to instructions provided by the manufacturer of the accessory).
Any damage caused by frost, including damage where a lack or failure of anti-freeze has been a contributory factor.
Any damage or losses to components that are not directly covered within the terms of this warranty.
The gradual reduction in operating performance (wear and tear) consistent with the age and mileage of the vehicle.
Any loss, damage or failure which occurs while the vehicle is outside the geographical territories.
All damage and repairs resulting from water ingress, for example, through damaged or ineffective door, window or roof seals, through doors or sunroofs left open, or caused by flood water.
Any routine component adjustment and alignment.
Vibrations and noises related to the operation of the vehicle.
Deterioration such as discolouration, alteration or deformation of parts due to normal ageing.
The consequences of repairs, conversions or modifications carried out by firms not approved by the manufacturer, and also the consequences of converting the vehicle to run on LPG.
Damage resulting from the use of fluids or parts other than original parts or those of equivalent quality.
Faults that existed prior to the commencement of the warranty.
Any vehicle used for hire or reward such as taxis or driving schools.
Any vehicle that is owned by a motor trader or garage or associated companies or by the proprietor(s) of such motor trader or garage.
