![]() | Home > Maintenance & Mods (L322) > Heater cold but engine normal |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8382 ![]() ![]() ![]() |
Could be an air lock or blockage in the heater, try removing one of the heater pipes and sticking a hose up it to see if water will pass through the heater...
Fil1138 Member Since: 21 Oct 2015 Location: West Midlands Posts: 6 ![]() ![]() ![]() |
From what I can tell the fbh doesn't do anything, either with the remote fob or by setting the times on the radio for it |
Needs a good look at with a diagnostic device then...
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1395 ![]() ![]() ![]() |
I've no experience of the TD6, but on my petrol 4.4s the final stage resistor in the heater system failed resulting in no heat into the cabin. I believe that is a common problem. Could that be relevant to the TD6 too? Only Range Rovers since 1988 |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
^^^^ very relevant - usually affects the fans but could impact on heat too. Worth a check/change out. .
I can't see how the FSR called an Output Stage (voltage amplifier) in Rave can make the OP's water pipes cold, it just controls the fans not the water valves...
I have had another go with it and found that the crossover valve has no power going to it thus to open it, is this what is supposed to happen or where does it get its power from ? |
As I said above, you should get the codes read, there will be something to point you in the right direction, guessing why there is no power to it doesn't really work.... it could be a direct feed or it could be can-bus controlled, the signal probably comes from the HEVAC ECU... could be that, or the FBH or something else.... I take it you have checked all the fuses...??? Pete
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
Crossover valve is only powered when FBH is on Nige |
As iron horse posted, the crossover valve IS powered by the FBH so I looked there and found the fbh had been unplugged from its power supply, I plugged it back in and power was restored at the crossover valve, but firstly the fbh ran but would not stop until I unplugged it from the power, and secondly it didn't seam to get hot or warm water, as heater vents only blew cold but could turn blower off and on with fob remote, any ideas why it won't stop running even when the car is locked, did leave it running for about half hour until I unplugged it ? |
if you interupt the FBH running cycle sometimes it can carry on running when powered back up (carrying on from where it left off)
