![]() | Home > Technical (L322) > New battery fitted - various issues! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35615 ![]() ![]() |
when i had my tints done the chap kept on opening and closing the rear windows with the ignition left on and flattened my battery which was fully charged , as in your case a quick battery charge and all was well again..
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
I have flattened my own battery while cleaning the car - all doors open and interior lights were on.
One reason why i run my engine when i give the FF a good inside and out clean as it takes a few hours and means i can have the old wireless on listening to music as i clean, and i can lower it to make the roof easier and lift it to clean the arches out and underside |
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 ![]() ![]() ![]() |
IN Short YES, very common
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Detailer should connect a C-Tek to the FFRR when he's working on it |
CY Member Since: 27 Mar 2007 Location: Scotland Posts: 146 ![]() ![]() |
Many thanks all for your responses - sounds like it's typical of the car rather than mine having some sort of ominous fault. I've got a C-Tek charger and have lent it to the detailer to use while he works on the car.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8518 ![]() ![]() ![]() |
Or change all your interior lights for LED's I regularly work all day on mine with the doors constantly opening and closing so the lights are on most of the day and I have no problems at all, also doesn't cost you a fortune burning fuel when washing it....
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
I use my cTek on "power" mode which just runs the car when doors etc are left open.
is this any good ash,
Oh dear... It goes from bad to worse...
It's very possible the battery has drained in two days if he was opening and closing doors all the time. Every time a door is opened the system awakens and takes 20 minutes or so to go to sleep again.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
If he left the key in (or near) the ignition switch all the time the immobiliser stays alive and drains the battery. |
Help!
