Home > Maintenance & Mods (L322) > Batterys
Ziggy
Australia
Batterys
Well after stuffing about with the IDTool trying to get the TV working the car would not start turned over but very sluggish....jumped from the old rangie and away we went.......
so after looking at the wiki a Bosh S5 120A/920 cca is recommended but that's serious money in the land down under so would this one do ..........or should I go genuine......
PART NUMBER HVT-86D
BATTERY TYPE AGM VRLA - Cyclic Use
VOLTAGE 12 Volts
CCA:(cold cranking amps) 1000
AH (20hr): 130
DIMENSIONS
Length 330mm
Width 173mm
Height 212mm
Terminal Height 220mm
TERMINAL TYPE
Satin Forged Brass
TERMINAL ASSEMBLY
OTHER FEATURES
WEIGHT 31.40 KG
REGULAR CHARGE 13.0 Amps
MAX CHARGE 36.4 Amps
PLATE TYPE Die Cast Grid
SEPARATOR TYPE Absorbed Glass Mat
USAGE Starting
Deep-Cycle
Marine
Standby
WARRANTY
Private use
3 Years
Thanks
Ziggy "Those who cannot remember the past are condemned to repeat it."
George Santayana
Puts away his cloth cap and donkey jacket
Goes and sits in the naughty corner
Post #353769 23rd Oct 2015 8:45am
rar110
Gday Ziggy
Biggest battery that will fit sounds like what these machines need. ______________________________
Post #353780 23rd Oct 2015 9:03am
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Also watch which way round the terminals are. Marine batteries often have different layouts. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #353820 23rd Oct 2015 12:57pm
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Hi Ziggy,
Look for Varta G14 or H3.
I have the H3 in my beast.
Plenty of power in them.
cheers
Post #353880 23rd Oct 2015 8:31pm
Ziggy
Australia
Thanks Guys, I thought bigger was better, the marine battery has more AH and CCA than the Bosh and the two little cub mentioned and the dimensions are about the same so if the terminals are OK I'll give that one a go.
That'll teach me to stuff around with the IIDTool and not have it running, but I guess it was a sign that the battery was on its last legs.
Zig "Those who cannot remember the past are condemned to repeat it."
George Santayana
Post #353889 23rd Oct 2015 9:48pm
