Home > Maintenance & Mods (L405) > L405 battery
London Lad
L405 battery
Has the 405 4.4 AB got one or two batteries and where are they please?
Post #352084 13th Oct 2015 5:24pm
2
One under the spare wheel - the other behind the drivers side panel in the boot :thumbs:
Post #352089 13th Oct 2015 6:01pm
wilwak
United Kingdom 2016 Range Rover Vogue SE TDV6 Corris Grey
Am I right in thinking that the smaller one is part of the stop-start system?
My modern Jaguars also have the same twin battery system.
The Stop-Stop OFF button is the most used switch in my cars.
Stop-Start in an Auto vehicle is just too slow to live with. Awful!
Post #352110 13th Oct 2015 7:39pm
mzplcg
You must have a lightning quick right foot then. The engine stops at TDC and is started as the brake pedal is released. By the time I manage to get my right foot on the gas the engine is well and truly running as if it had never stopped. It's a good thing IMHO. Saves fuel, peace and quiet at the lights, nothing to not like really.
Post #352112 13th Oct 2015 7:58pm
Mine doesn't have stop/start - so the smaller battery might do that, but must do other things as well.
Post #352114 13th Oct 2015 8:05pm
Maybe it's LR's way of acknowledging that two batteries is he only real way to run park heat properly after the fiasco with the later L322's 😂 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #352140 13th Oct 2015 10:47pm
London Lad
Thanks for that gents. I would be interested to know exactly how the two batteries are utilized. I have had a number of cars with two batts fitted from the factory.
One used one batt exclusively for unlocking and starting and the second for everything else. Another car ran entirely from its 'main' batt but kept a smaller batt fully charged for emergency starting which was activated by turning the key a quarter turn backwards prior to starting.
Post #352182 14th Oct 2015 8:53am
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
Which one would you plug the ctek onto? Or should you use the connections under the bonnet as for jump start?
Post #385510 6th May 2016 8:19am
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
Hi wealy I would only use the points under the hood or you fry computers for jump starting or trickle charging battery.
Post #398174 29th Jul 2016 6:10am
