Home > Maintenance & Mods (L322) > Members BEWARE Winter is coming...
Page 4 of 4 <1234
fyi not this type of Gummi either....
 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #353138 19th Oct 2015 3:34pm
Tom Paine
Australia 2003 Range Rover HSE Td6 Bonatti Grey
I see that this post is dedicated to small wet islands in the northern hemisphere. At this time of the year we are checking our air-conditioners and buying windscreen sun shields - and checking for cyclones.
Less concerned with rust and more concerned with being swept downstream.
Post #353411 21st Oct 2015 7:12am
Perth mate nothing but isolation and sunshine till after Easter Thumbs Up
And our nearest Croc is Simmo and he is in the zoo Laughing 2008 MY Supercharged
Post #353421 21st Oct 2015 8:12am
Crocs, Sharks, and things that grow on your skin and kill ya....
and dont get me started on those 8 legged things and slithering things! Rolling with laughter FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #353444 21st Oct 2015 10:19am
pld118
Check your rear wiper blade. Ours was tired and tired wiper blades, leave unsightly and obvious scratches on expensive to replace glass and during winter, every time you push that stalk forward to clear the crap off the rear window so you can see what is behind, you might well be scratching away at the glass if your aged wiper blade has been forgotten about.
Just replaced ours today. A bargain LR product at £20.99 Shocked
Reduced from £27.99 though Thud
Post #355750 7th Nov 2015 5:18pm
Zirconblue
You can buy polishing kits to remove scratches from glass. Wink
The rear blade is nothing special, you can get them much cheaper elsewhere.
Powerful do a complete arm, blade and washer jet kit for £50. - the pivots on the arms seize up and stop them pressing the blade on the screen properly.
Post #355751 7th Nov 2015 5:29pm
pld118
Aye and if you've ever used a glass polishing kit for proper scratches you'll know that it's hours and hours of a horrible job requiring machine tools, expensive Ceriglass polish and the patience of a saint. So, just monitor the condition of wiper blades, keep your glass clean and avoid the hassle Thumbs Up
And as Stan points out, you can get wiper blades for £1 in mainstream shops.
See... My window glass is so well maintained and clean, they saw me coming for an overpriced rear wiper blade Laughing
Post #355752 7th Nov 2015 5:41pm
Zirconblue
I bought a kit for about £15 off ebay or amazon, ceriglass polish, polishing pads and holder. Worked a treat on the windscreen of my mums car. Most people already have an electric drill.
I suppose it took about an hour to bring a bad wiper arm mark to an acceptable standard.
Agreed, far better to replace the blades before it gets that bad, but it has to go a very long way to need replacement glass. Smile
Post #355753 7th Nov 2015 5:52pm
£20!!!!! Be Jesus!!!
I paid £3 for mine although it is for a Renault 5.... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #355756 7th Nov 2015 6:20pm
miggit
Shocked Any 18" hook type wiper blade will fit, £3 for a blade Shocked I hope it was branded, you can get a pair for that kind of dosh!
Rear wiper arms do seize up, there is no quick fix that I've found Sad You need to remove the rear spoiler (3 Bolts, then slide it rearwards and lift, key hole slots), so that you can pivot the arm threw its' full travel and add some WD while your wiggling it back and forth. And we are talking about the wiper arm here folks, you could fall foul of the law if it's anything else Embarassed Laughing
It doesn't take much to get the arm working properly, but you do need the full 90 degree travel Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #355783 7th Nov 2015 11:25pm
pld118
Just for you Zircon, it seems not everyone has found it as easy to remove scratches to a standard they're happy with, a drill isn't always going to do the job, you can buy a replacement wiper blade cheaper than a glass polishg kit and people do indeed resort to replacement glass Wink
http://www.fullfatrr.com/forum/topic18617....p;start=15
Our last one had unsightly scratches to the rear factory privacy glass because replacement of the rear blade had been neglected and the metal damaged the glass. It wouldn't polish out and left white marks visible against the 'black' glass. Thumbs Up
Post #355816 8th Nov 2015 9:24am
In this case it would seem that prevention is better than a cure... Thumbs Up
Post #355831 8th Nov 2015 10:49am
pld118
Check your nuts
Checked my nuts yesterday. Had the car 4 or 5 months and never checked them until now Embarassed
Worryingly, the front passenger side nuts were not well torqued at all... And one of the nuts appears slightly swollen as it was difficult to get the wheel brace onto it. Have got replacement nut stocks anyway but must be worth 5 minutes of your time checking your nuts with a wheel brace... In any weather! Thumbs Up
Post #356284 11th Nov 2015 2:55pm
Air gun impact wrenches will swell your nuts - I always insist mine are done by hand Thumbs Up
Post #356285 11th Nov 2015 3:02pm
miggit
^^ Shocked I'd say, and bring tears to your eyes Shocked Rolling with laughter
On the earlier ffrr's, like mine, corrosion also contributes to the over sized wheel nut, LR didn't rust proof them very well Evil or Very Mad Yesterday I couldn't spell Engineer... Today I are one!
Post #356287 11th Nov 2015 3:15pm
Page 4 of 4 <1234
