![]() | Home > Maintenance & Mods (L322) > 4.2 SC Mid resonator delete |
JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303 ![]() ![]() ![]() |
Forgot to post in here. Mine has been done now.
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Any more videos of this?
axanon Member Since: 28 May 2020 Location: Central Posts: 4 ![]() ![]() ![]() |
Would be great to hear and see if still possible!? ![]() I'm thinking about the removal of both resonators too - but as it's forbidden in switzerland to change parts on a running vehicle, i'm looking for a method, without 'seeing' the change at first sight. maybe it's possible to remove the parts, open the resonators from above, remove the inside (soundproofing), and reassemble it all together. should be hidden for the main 2-year-inspectation... what do you think? possible? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
To add my 2peneth... If you then change/fit a 5.0 rear exhaust box, the sound then quietens down to a much more subtle sound! This i did on a 4.2 SC of my own a while ago... I found mine to be too loud BUT, mine had done some miles and thus could have made the rear box cook?
sounds interesting too! but do they fit on the 4.2SC...? |
Yes... I fitted one to mine as stated above sir... |
