Home > Technical (L322) > Leaking blue air suspension pipe,
keefy1959
United Kingdom 2006 Range Rover Vogue SE Supercharged Buckingham Blue
Hi all, got the dreaded leaking blue suspension pipe that is common to the FFRR ,osr pipe chafed on chassis etc etc, i have read in the forum and bought the repair kit and seen the before and after pics and it looks tricky but straightforward to do, but, [unless i missed it ] no-one seems to have put in the procedure on how to do it, i.e., do you have to drain down the suspension first, do you have the air spring fully compressed or fully extended, what does that particular blue pipe do? don't want to just cut through it and have 3 ton of range rover on my chest !! also is there a way to stop it trying to raise while I'm there [some one mentioned leaving the tailgate open] remove a fuse , if so what one? once I've done it is it just a matter of starting it up and going through the suspension up/down routine ? got plenty of mechanical experiance ,none of it with air suspension !! hope theres enough info there guys, thanks in advance of a reply !!!! Razz Razz Supercharged 4.2 FFRR in Buckingham Blue,
Gone, Ford Explorer 4.0 V6 petrol,
Gone, Ford Granada Estate Ghia,
Gone, Daimler sovereign 4.0,
Raced, more mk1 & 2 granada's, A60's mk1 cortina's and mk 3 zodiacs than i can remember!
If its too loud then you are too old!!!
Post #351042 7th Oct 2015 4:27pm
Where is the pipe that's holed??
Leaving a door open will stop the suspension from levelling, leaving the boot open does nothing... Pete
Post #351046 7th Oct 2015 4:57pm
DMRR
Mine came from the factory with a punctured hose (robot had tried to push a connector through it). I fixed it with duct tape until the dealer could get a replacement - which was about 4 weeks. Duct tape is of course the LR repair tool of choice for this job as baling twine was too thin Wink Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #351200 8th Oct 2015 11:42am
keefy1959
pete , the chaffed blue pipe is on the offside rear where the pipe runs over the rear cross member, looks like it comes from the compressor and heads towards the back of the car, can't see where exactly,
thanks for the swift replies btw !!!! Supercharged 4.2 FFRR in Buckingham Blue,
Post #351233 8th Oct 2015 2:21pm
If it comes from the compressor then it's going to the air tank, should be OK to chop through it then, if you need to get under it then I'd be tempted to put some axle stands under it just in case, then leave one of the doors open, do the fix, remove the stands, start the engine and let the pump run till it stops then try out up and down, should sort it.. Thumbs Up Pete
Post #351245 8th Oct 2015 4:13pm
keefy1959
thanks pete,much appreciated !! Bow down Bow down Supercharged 4.2 FFRR in Buckingham Blue,
Post #351252 8th Oct 2015 5:18pm
johnboyairey
cant you just cut it (at the damage), and recouple it with a pneumatic pipe push connector? for pence, like these. http://www.ebay.co.uk/itm/8mm-Straight-Pus...542560b024
you can drop it down to the bumpstops somehow, as i seem to remember with a diagnostic tool.
Post #351271 8th Oct 2015 7:16pm
I don't think he needs to, the pipe in question goes to the air tank, he's got the repair kit, basically an 8mm straight connector, just cut the hole out the pipe and connect it up... Thumbs Up Pete
Post #351276 8th Oct 2015 7:45pm
