![]() | Home > LPG > 4.4 Jag and SC owners on LPG |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
had mine 3 years with zero problems so far related to lpg. obvs had the usual everything else.
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2290 ![]() ![]() ![]() |
4.4 jag, self lubing BRC since nearly new, now on 80k mls, no problems (yet |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
2 years no problems , lube oil system fitted
Voguese1 Member Since: 29 Nov 2016 Location: Wirral Posts: 2 ![]() ![]() ![]() |
Had my E-gas system fitted in 2007 at 34k miles no lube system. Had heads re-valve seated at 64k ish withhardened seats. No issues since then. Now got 140k miles on clock and no valve related issues.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
@Voguese 1
I assume you mean the LPG fueling.
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 ![]() ![]() |
Now at 200K (miles) most of it on LPG , had to have the valves re shimmed at 160K apart from that all ok.
The LPG tank is under high pressure so I really don't know if that would be possible, but I like the idea. Have to look into that in Holland, where lpg is rather common. Never heard of that system here in France. |
i was thinking of a Tee into the fill line, a quick fit hydraulic connector linked to a hand pump (remember the old hydolastic pumps) pump in 70ml to the fill line and then fill with 70 liters of LPG , Simples if i ever get around to doing it ? |
yep why not, here in France they would probably ban me from the road, here the LPG system is checked every MOT. Add the lube in the LPG at the pump is not a bad idea. |
Bullit_666 Member Since: 06 Feb 2019 Location: North yorkshire Posts: 22 ![]() ![]() |
Am i right in thinking that the 4.2 doesnt like to be converterd unless the seats are hardened? Heard a lot of horror stories and the like |
30000 miles on lpg
Peopete Member Since: 18 Mar 2019 Location: Birmingham Posts: 43 ![]() ![]() |
Hi all I need my 4.2sc converting, rang a lpg installer who dose stag and brc, he recommended the stag with a lube system even thou the brc system was £700 more. Any ideas please. |
http://www.lpgc.co.uk
