Home > Wheels & Tyres > 22in wheels tyre pressures
Haylands wrote:
It's easy to determine the correct tyre pressure
Shocked Wow - I'd hate to hear the hard & time consuming way Whistle Rolling with laughter
Post #351565 10th Oct 2015 4:45pm
You can calculate the correct tyre pressures for a given tyre
Find the max load per tyre say 950kg for sake of argument (it's not but I can't be bothered to go and look.....)
950 x 4 = 3800kg max load
3800 / max gross weight say 3200kg = 1.1875
Find the max pressure of the Tyre on the tyre wall. Say 45psi....
45psi / 1.1875 = 37.89
So inflate to 38 psi.
All figures are made up so you need the proper numbers but you get the idea. There is nothing that can't be fixed with a hammer😜😜
Post #351611 10th Oct 2015 8:33pm
Pfazz wrote:
My 2016 tyre pressures from factory are
Light load 34front 37 rear
Heavy load 40 front 47 rear
Hope this helps.
Bow down Bow down Thank you sir Thumbs Up Thumbs Up
Post #351626 10th Oct 2015 10:59pm
