![]() | Home > Off Topic > Auto or Manual for reliability ? |
I prefer automatics in this case. If maintained properly they are gentler on the engine, last a lot longer than normal clutches etc. Apart from the TD6 GM box of course |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8509 ![]() ![]() ![]() |
Can't see the point of a manual... all the car makers make cars easier to drive with electronics and gadgets that turn everything on and off for you, speech recognition etc etc and then they put a 6,7 or 8 speed box in it so you have to change gear all day long.......
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
There are certainly some poor transmissions of both types and, for one particular model, there might be a clear choice.
Good points above |
All diesels and powerful petrol cars with manual transmissions have dual mass flywheels now and as Craig just said when they have done destroying your clutch they follow right behind at great expense , my wife's T5 practically had me in tears it was so expensive for what appeared to be a clutch plate and a springy disc of metal . So with regular oil changes it's automatics all the way for me and it is much harder to abuse an automatic |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
My cars are a mix between auto and manual and my view is it's not just the make and age of gearbox but, when buying secondhand, how it's been treated since new.
Vikash Member Since: 22 Apr 2013 Location: Milton Keynes Posts: 29 ![]() ![]() ![]() |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 ![]() ![]() ![]() |
thanks for the input |
Absolutely. Most mechanics can repair a manual. For autos, the mechanic just takes it out and sends it to a specialist. (Well, except for Ebajema who fixes them himself! |
Simple question that has the biggest affect on the answer, well two really...
