Home > Off Topic > Auto or Manual for reliability ? |
I prefer automatics in this case. If maintained properly they are gentler on the engine, last a lot longer than normal clutches etc. Apart from the TD6 GM box of course MY 2010 5.0 SC Galway green and sand interior!!
26th Sep 2015 12:00pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Can't see the point of a manual... all the car makers make cars easier to drive with electronics and gadgets that turn everything on and off for you, speech recognition etc etc and then they put a 6,7 or 8 speed box in it so you have to change gear all day long.......
26th Sep 2015 12:19pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
There are certainly some poor transmissions of both types and, for one particular model, there might be a clear choice.
26th Sep 2015 11:28pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
Good points above
26th Sep 2015 11:38pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
All diesels and powerful petrol cars with manual transmissions have dual mass flywheels now and as Craig just said when they have done destroying your clutch they follow right behind at great expense , my wife's T5 practically had me in tears it was so expensive for what appeared to be a clutch plate and a springy disc of metal . So with regular oil changes it's automatics all the way for me and it is much harder to abuse an automatic 2008 MY Supercharged
27th Sep 2015 4:56am |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
My cars are a mix between auto and manual and my view is it's not just the make and age of gearbox but, when buying secondhand, how it's been treated since new.
27th Sep 2015 12:46pm |
Vikash Member Since: 22 Apr 2013 Location: Milton Keynes Posts: 29 |
FF RR Vogue 2003 TD6 |
27th Sep 2015 1:26pm |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 |
thanks for the input
27th Sep 2015 5:55pm |
Absolutely. Most mechanics can repair a manual. For autos, the mechanic just takes it out and sends it to a specialist. (Well, except for Ebajema who fixes them himself! That's hard core.)
27th Sep 2015 8:42pm |
Simple question that has the biggest affect on the answer, well two really...
27th Sep 2015 10:20pm |
