![]() | Home > Technical (L322) > Cabin Noise TD6 v TDV8 4.4 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
interesting |
Note that the dB scale is a logarithmic scale, in other words, the 2 points difference is actually quite a lot in real life even if it seems little seeing both numbers so close together. MY 2010 5.0 SC Galway green and sand interior!!
Sql Member Since: 27 Jun 2015 Location: Poland Posts: 252 ![]() ![]() ![]() |
Interesting, thanks for taking your time to do that.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7909 ![]() ![]() ![]() |
That's all well and good, but I'm still struggling with the £20k to change......
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Thanks for posting. Are the later tdv8s double glazed, , or was it an option.
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 188 ![]() ![]() ![]() |
All later models (post 2010 I believe) came with acoustic glass on the front windows as standard. |
The side windows are all laminated.
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 ![]() ![]() ![]() |
Is the hi fi any good ?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Conti silent tyres are very good...👍 |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2647 ![]() ![]() |
Yes, especially with the more aggressive tyres now fitted. I notice the absence of sound-deadening material on the ends of the compartment in front of the windscreen which I suspect allows a fair amount of noise to be transmitted. |
these look interesting - and a radical concept as the tyre contains a foam insert. They don't appear to be available in my size, which is 255 55 R19, and are summer only. Also, the Goodyear Efficient Grip tyres don't seem to available in this size either! So when the time comes I may have to look for something else 2011 Vogue TDV8 4.4 1992 Mazda Mx5 |
I wonder what it would be like on a TD6 like the one i drive which has the double glazing all round... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
It dawned on me that my oversized spare does not sit on the floor of the well so the floor is free to resonate. That situation will be changed ASAP. |
