Home > Maintenance & Mods (L322) > IID Tool BT is it the tool or me
Tinman
Why will my IID BT not pick up that I have a suspension fault? It has been updated in the last 3 weeks I am still getting a yellow triangle warning and briefly a red then went off back to yellow checked and no faults are shown?
Something is not telling the compressor to work, vent or pump, when looking at raising suspension with IID tool the temp on the compressor is around 32 degrees and not raising.
I`m a bit at a loss as to what`s happening? If I can`t see it I can`t fix it?
Post #538461 25th Dec 2019 8:36am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Did you scan for error codes across all ECUs? 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #538464 25th Dec 2019 11:12am
Tinman
Yes I did the Advance scan all ecu`s still no errors
Post #538465 25th Dec 2019 11:15am
MikeO
No errors in any ECU? That does seem a bit unusual in my experience at least Laughing
Do the live values of other things look okay? Ie can you see things changing as you would expect? 2016 Skoda Octavia VRS Estate
Post #538468 25th Dec 2019 12:42pm
Tinman
Well I stand corrected I discounted the same two that are always their door speaker not working and door lock but they have been showing since I bought the IID Tool not Checked any live values yet just driving me up the wall?
Post #538470 25th Dec 2019 2:38pm
DrRob
You may just have a dud tool? Does happen. Maybe get in touch in Pat at Gap....? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #538471 25th Dec 2019 2:49pm
Tinman
That`s my next thought after the festive season see if he can come up with anything?
Post #538472 25th Dec 2019 4:22pm
DrRob
Defo worth an email Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #538473 25th Dec 2019 4:31pm
MikeO
Couple of thoughts. You could try checking ECU Info's for the suspension module to see if it's recognised and communicating okay. Or temporarily changing a suspension height just to check the IID is able to communicate with the suspension module.
You could also try a hard reset (of the car) just in case it is a comms glitch and that fixes it.
Or wait for Pat who I'm sure will sort you out. 2016 Skoda Octavia VRS Estate
Post #538477 25th Dec 2019 5:03pm
Tinman
OK, this morning I thought I would try the car with changing the suspension height? I started the car put the car into `N` selected off road and selected raise height up she went, Held the raise height button and up she went pressed the button again to come down which it did and the to access height all ok? So what did I do well yesterday when under the bonnet I noticed that the wires from the adaptive suspension were out from the holder with the rubber grommet which I had replaced with new from Duckworths So I checked both sides that they were ok, put it back together closed the bonnet until this morning and as said before no bong. I will test drive later could it be that simple?
Post #538507 26th Dec 2019 9:36am
