Home > Technical (L322) > Trans failsafe prog |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 |
The metal you describe on the magnet, this is normal.
27th Aug 2015 5:12pm |
srpara Member Since: 03 Oct 2013 Location: moray Posts: 115 |
Hi
27th Aug 2015 5:42pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8334 |
Have you tried it in manual mode?? could be the selector switch hopefully.... Pete
27th Aug 2015 6:40pm |
Yes works ok in manual changes up and down no problem but after half a mile it goes into failsafe, also tried it in auto and again goes thru the gears with no problem but then once again goes into failsafe.
27th Aug 2015 7:58pm |
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 |
did they also change the oil cooler for the gearbox when you got a new one? |
28th Aug 2015 7:55am |
it was the last owner that had the box changed so not to sure. |
28th Aug 2015 1:02pm |
UPDATE on the box:-
28th Aug 2015 1:18pm |
Sorry to hear that mate.
28th Aug 2015 2:28pm |
It's a pain The fluid I put in on the change was Texamatic 7045E which was not cheap and as it turns out didn't get much use |
28th Aug 2015 2:50pm |
I find it really confusing that Land rover could claim the GM box as being sealed for life, especially with a mineral based fluid.
28th Aug 2015 4:10pm |
I think this is probably more to do with the quality of the rebuilt box than anything else, it is easy to do the minimum on rebuild to get it to last outside the warranty period and little more...
28th Aug 2015 8:10pm |
Just to update on the problem, I got a recon box and torque converter from Mackie Transmissions in Glasgow ( the place is huge and they have very good reviews) total cost £1840 also got new oil cooler, both pipes, o seals and pipe clamp from Dan @ Duckworth around £400 the lot.
14th Sep 2015 3:47pm |
Trossachsturbo Member Since: 29 Jan 2014 Location: Central Posts: 24 |
Good news.remember the oil cooler is dependent on the bottom 5 rows of the radiator, so most of these older ones have had at least one new radiator. |
15th Sep 2015 8:07am |
