![]() | Home > Technical (L322) > Door Mirrors dont fold in. |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
When I push the button to fold in the mirrors just cycle to recalibrate. Any thoughts? |
press the button two or three times really quickly to re-sync , repeat until fixed . It's a known problem and easy fix . 2008 MY Supercharged
NormanP Member Since: 15 Mar 2013 Location: Oxford Posts: 136 ![]() ![]() ![]() |
http://www.fullfatrr.com/forum/topic22778.html Norman
Thanks guys I will give it a try tonight. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8450 ![]() ![]() ![]() |
Also found out the other day there must be a minimum speed that they will fold in at.... Tried to fold them in on the motorway to see if it changed the wind noise much and they wouldn't fold, thought they were bust but as soon as I slowed down they worked again...!!! Pete
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
Yes they won't fold in at speed. Mine are the same. I've also had problems getting them to fold in at stationary. I press the button repeatedly until it locks me out, then leave it around 3 minutes and it all works again. Weird. Also, you will find the auto dipping passenger mirror when in reverse won't actually dip if the mirror control switch is set to the left, it needs to be set to the right for this feature to work |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
There is, i read it in the handbook. I can't remember the exact figure though, 10mph maybe? Presumably if you already have them folded in you can fold them OUT at speed, but not back in again. |
the thing where the mirror wont dip to the kerb position when you flick the switch across is by design too. I use it if im for example, reversing a trailer, having the mirror dip down it only good if you're parking in the street, other wise it's more of a hinderance. |
