Home > Technical (L322) > Door Mirrors dont fold in.
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
When I push the button to fold in the mirrors just cycle to recalibrate. Any thoughts?
Post #344260 25th Aug 2015 2:47am
ebajema
There is a re-homing procedure on here somewhere. Yours just lost their two home positions (folded and fully out) and that needs to be relearned. Have a go with the search function or hope Stan does it for you Laughing MY 2010 5.0 SC Galway green and sand interior!!
Post #344261 25th Aug 2015 3:49am
press the button two or three times really quickly to re-sync , repeat until fixed . It's a known problem and easy fix . 2008 MY Supercharged
Post #344262 25th Aug 2015 3:57am
NormanP
United Kingdom 2014 Range Rover Vogue TDV6 Aintree Green
http://www.fullfatrr.com/forum/topic22778.html Norman
Current LR: L405 Vogue TDV6 (MY 2014) Aintree Green/ Ivory interior
Past LR: L322 Vogue 4.4 V8 (2002); Discovery series1 V8 (1995)
Post #344267 25th Aug 2015 5:49am
doclees
Thanks guys I will give it a try tonight.
Post #344319 25th Aug 2015 1:45pm
Also found out the other day there must be a minimum speed that they will fold in at.... Tried to fold them in on the motorway to see if it changed the wind noise much and they wouldn't fold, thought they were bust but as soon as I slowed down they worked again...!!! Pete
Post #344331 25th Aug 2015 2:18pm
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
Yes they won't fold in at speed. Mine are the same. I've also had problems getting them to fold in at stationary. I press the button repeatedly until it locks me out, then leave it around 3 minutes and it all works again. Weird. Also, you will find the auto dipping passenger mirror when in reverse won't actually dip if the mirror control switch is set to the left, it needs to be set to the right for this feature to work Smile
Post #344348 25th Aug 2015 3:53pm
Zirconblue
There is, i read it in the handbook. I can't remember the exact figure though, 10mph maybe? Presumably if you already have them folded in you can fold them OUT at speed, but not back in again.
Post #344381 25th Aug 2015 6:47pm
Zirconblue
the thing where the mirror wont dip to the kerb position when you flick the switch across is by design too. I use it if im for example, reversing a trailer, having the mirror dip down it only good if you're parking in the street, other wise it's more of a hinderance.
Post #344383 25th Aug 2015 6:49pm
