Home > Technical (L322) > FBH |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Yes in the cold weather iit will warm engine and interior.
21st Aug 2015 9:58am |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
^^^ as above.
21st Aug 2015 10:15am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
As well as economy i suppose it makes the engine more willing to start and reduce engine wear in really cold climates, like Poland, Finland, Siberia and Scotland. |
21st Aug 2015 10:34am |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
Don't know about more willing to start,just makes the cab a bit more comfortable waiting for the AA to jump start you |
21st Aug 2015 1:19pm |
When you use the remote or timer on the FBH it does not heat the engine , there is a by pass valve and it only heats the cabin but on starting the engine and it is below a certain temperature 7 or 8 degrees from memory it will continue to work to help bring the engine up to temperature quicker to help with emissions . 2008 MY Supercharged
22nd Aug 2015 4:18am |
