Home > Technical (L322) > FBH
apole
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
FBH
Hi,
With the remote controlled aux heater, does this just provide the heat for the internal heater matrix's or heat the entire cooling system?
Tried mine this AM, interior fans come on straight away and heat comes out pretty soon after (OK it's not a cold day but engine was cold).
Just wondering how it works as nice to have pre-warned interior on cold days but also nice if poss to pre-heat engine.
Also does it warm inside up to what the heater control is set to, or just keep going, presuming up to set level as on timer setup it lets you set temp.
Thanks guys, still learning !
Post #343572 21st Aug 2015 10:48am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Yes in the cold weather iit will warm engine and interior.
Something to do with economy Laughing Laughing Laughing
if there's such a thing on an rr. Very Happy
greg Thumbs Up
Post #343576 21st Aug 2015 10:58am
proser
^^^ as above.
Fitted one to a D2 years back and made a big difference to the sound of the engine on a cold winters morning, and was nice and toasty on the inside Very Happy Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #343583 21st Aug 2015 11:15am
Zirconblue
As well as economy i suppose it makes the engine more willing to start and reduce engine wear in really cold climates, like Poland, Finland, Siberia and Scotland.
Post #343590 21st Aug 2015 11:34am
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
Don't know about more willing to start,just makes the cab a bit more comfortable waiting for the AA to jump start you Thumbs Up
Post #343618 21st Aug 2015 2:19pm
When you use the remote or timer on the FBH it does not heat the engine , there is a by pass valve and it only heats the cabin but on starting the engine and it is below a certain temperature 7 or 8 degrees from memory it will continue to work to help bring the engine up to temperature quicker to help with emissions . 2008 MY Supercharged
Post #343704 22nd Aug 2015 5:18am
