Home > Maintenance & Mods (L322) > Castrol Magnatec for VANOS rattle |
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 |
I had my oil changed and refilled with Castrol Magnatec 5W-40 C3 Fully Synthetic about 3000 miles ago. The dreaded rattle appeared about 500 miles before the oil change - and has not gone away in the slightest since the change. My rattle is a constant one, not just on startup. NW060
21st Aug 2015 8:35am |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 |
Just got around doing the left check valve(as you look under the bonnet). Ended up needing to borrow the PO socket for removal. I think he misread the torque settings because I needed to add a 2 ft pipe breaker bar to get it off. No way was it coming off with a band wrench. If it was torqed correctly then I'm sure it would. |
20th Sep 2015 7:26pm |
Replaced the second check valve since I had to drain the system to fix a leak. 98% of the vanos rattle is gone. Used a standard 32mm socket but thinned the wall about 2.5mm with a stone wheel. Like the last solenoid this one was torqued much too tight. |
23rd Dec 2015 4:26am |
