Home > Maintenance & Mods (L322) > Castrol Magnatec for VANOS rattle
ebajema
Lucky you, you get to make your hands dirty again Smile. MY 2010 5.0 SC Galway green and sand interior!!
Post #343225 19th Aug 2015 7:03am
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
I had my oil changed and refilled with Castrol Magnatec 5W-40 C3 Fully Synthetic about 3000 miles ago. The dreaded rattle appeared about 500 miles before the oil change - and has not gone away in the slightest since the change. My rattle is a constant one, not just on startup. NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #343558 21st Aug 2015 8:35am
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
johnboyairey wrote:
you can actually turn the solenoids out with just pump pliers used with some protection, on the actual solenoids as they are not supertight. its in a search of 'e39 vanos m63tu proceedure'
http://www.beisansystems.com/procedures/m62tu_vanos_procedure.htm
edit, here too. (simpler version!) http://www.bimmerboard.com/forums/posts/720836/
mine are mouse-quiet at 160k
Just got around doing the left check valve(as you look under the bonnet). Ended up needing to borrow the PO socket for removal. I think he misread the torque settings because I needed to add a 2 ft pipe breaker bar to get it off. No way was it coming off with a band wrench. If it was torqed correctly then I'm sure it would.
Post #348679 20th Sep 2015 7:26pm
doclees
Replaced the second check valve since I had to drain the system to fix a leak. 98% of the vanos rattle is gone. Used a standard 32mm socket but thinned the wall about 2.5mm with a stone wheel. Like the last solenoid this one was torqued much too tight.
Post #363576 23rd Dec 2015 4:26am
